Bad PCV?
Hey Guys,
i`m having some trouble with my 2015 O3 RS TSI DSG.
Between 1000-2000 rpm i hear some healing inside. I dont know if this is my DSG or the engine.
So yesterday i checked my parts at the engine and found this hose (attached).
After that i searched the web for possible failures.
Every 2nd Topic was PCV ...
I did some checks to figure out if its really the pcv:
- engine in idle -> put oil cap off -> was a bit hard because its a bit sucked
- engine in idle -> dipstick off -> hear suck noise every time i put it off
- engine in idle -> if i put off oil cap the engine starts ingreasing rpm
What do you think?
Can you use a different word? Healing does not make sense in a car context.
PCV (positive crankcase ventilation)- how does that go wrong?
https://axleaddict.com/auto-repair/How-to-do-a-PCV-valve-test
Doesn't sound like you have positive pressure in the engine.
Edited by gregoir
other words: crying/howling
sorry for that :)
part of the pcv is a diaphragm which can be leaky.
It sounds (literally) like your diaphragm is leaking.
I think when they leak, you get too much suction (at idle), not too little.
Edited by Wino
is there a little suction if pcv is good? like its only increasing suction?
that would be bad to inspect.... how do i know if the suction level is ok? :D
I think I was maybe getting confused.  The amount of flow at idle should be reduced by a working system with an intact diaphragm, compared to one with a leaking diaphragm.
Not sure how the amount of suction that is apparent would be affected.
Here's a picture of one in two conditions of manifold vacuum (higher intake vacuum on right picture).  I think if the intake manifold is more connected to the crankcase (like if the diaphragm is torn and not moving down enough), there will be more/deeper vacuum in the crankcase at idle, no?
Usually you can unclip a plastic cover and visually inspect the diaphragm itself
Edited by Wino
It must all be more complicated in a turbo car...but I don't know about those.
Thank you.
I will go straight to replace this piece.
Gonna report after replacement.
I changed the Part today... man this was rough :) watched Videos on YouTube but mine was a Bit different.
so on. The engine has same behavior... i think It was ok then. I found little oil in the air intake. At home i opened the Old part and it Seems ok. No leaks at all.
  • 4 years later...
@swarly have you solved your problem? I have the exact same engine and exact same issues. Already replaced the pcv with oem part, but i still have very strong suction when i try to remove the oil cap and also when i removed it the rpms go up.
