Obdeleven mods and car battery change
Once you replace your car battery, will obdeleven changes you made berfore remain?
Yes, they are stored in non-volatile memory.
Remember to tell the battery management system that you have fitted a new battery  (if it's the small type and capacity just change the stored serial number) otherwise it will still be trying to "protect" the old battery.
How do you do that? Not that I need to, but might one day...
https://youtu.be/__ISlLOP2NE
Why does it want to know the make and serial number?
Serial number being changed tells the battery management system to re-learn the characteristics of the newly fitted battery instead of just using those of the old (knackered?) battery.
Make can be important as due to different internal construction makes can have different charge/voltage characteristics.
Never knew that. 👍
