Columbus Map Update 2020 (MIB1/MIB2/MIB2GP)
Still running on CLI, recognised the card size OK. I have a few things to try now.
Thanks.
There is a useful little utility called Fat32Format that I have used for about 3 years now when I need to use a big card, does most of the heavy lifting for you, but also allows you to configure the perameters yourself if you want to go more advanced. Might be worth a look for you, I am running windows 10 latest 2004 version
I have also used SD Card Formatter in the past with good success.
Edited by kentphil1
Use that one as well but not on map SD cards. My map cards are 32 GB. I cycle between the last release and the current release for the high :).
Standard, a cloned 32 gb card and 32gb Skoda card, plus the one in the car. They are for experiment. All fat32.
Have all the bases covered :).
Guest
