Snow chains on 225/50 R17
Hi
Hope this hasn't already been covered elsewhere but I'm wondering if any one has used snow chains on 225/50 R17s? They are not listed as a size compatible with chains in the user manual for my Octavia Scout. I rang Skoda UK who were little use and suggested I get in touch with Skoda in France.
Any advice, suggestions?
Thanks Neil
8 hours ago, NeilBr said:
Hi
Thanks Neil
Octavia Scout
Only fit snow chains with links and locks no larger than 12mm
205/55R16 6Jx16 ET48
205/55R16 6Jx16 ET50
205/50R17 6Jx17 ET45
205/50R17 6Jx17 ET48
Only fit snow chains with links and locks no larger than 9 mm
205/60R16 6Jx16 ET48
205/55R17 6Jx17 ET48
However, check the manual to be sure:
https://ws.skoda-auto.com/OwnersManualService/Data/en/Octavia_5E/07-2019/Manual/Octavia/A7_Octavia_OwnersManual.pdf?_ga=2.265642895.1804657306.1573767946-29f6f1bc-6506-4e56-856f-710808a18ce6
There's no mention of 225/50R17 tyre size. It's not just the tyre size, you also have to consider the rim width and the rim offset that the tyre is fitted to. 6J means the rim is 6"wide. ET48 means the rim has an offset of 48mm.
Edited by Carlston
Thanks for the reply. I'd already checked the manual and can only agree with your info. I'm going to fit all season tyres and maybe purchase some 7mm chains and hope I dont ever need them.
