Skoda SuperB Facelift MY 2020 Coding List and Adaption
Hi, NO IT does not work for new camera  2q0 980 653, also coding is difference...
Still no solutioon...
For High Beam and VZE it is probably necessary SWAP Activation for that functions....
  • Replies 92
  • Views 55.6k
  • If you only have high beam assist, it's probably a lowline. If you have either lane assist or traffic sign recognition, it's a highline.   Typically the following is true: - A lowline (
  • Topic was started for VZE activation on new Skoda Superb Facelift....   Not for circus for all adaptions....
  • Hi Davor,   I have a Skoda Superb 2019 FL and i’m using Obdeleven to code. I tried following some older coding guides for the pre-FL but I bumped into some issues: - Disable auto s
1 hour ago, fergard said:
Can someone confirm this for 2020 Superb?
didn't work, I tried
On 21/02/2020 at 16:30, Egk said:
Here is the coding for the lane departure warning and lane assist working in my MY20 Superb Combi. Camera is the new Valeo cam "MQB MFK 3.0":
STG A5 > Codierung > …
> Byte 05 > Bit 6 aktivieren („ACC“, 1-coded)
> Byte 08 > Bit 5-7 auf "A0 Point_of_Intervention,late_setting_over_menu" setzen
> Byte 09 > Bit 0-1 auf "03 Configuration_for_lane_departure_warning_kl15,Last_setting" setzen
> Byte 09 > Bit 2-3 auf "0C Lane_Assist_system_mode,Selection_over_menu" setzen
> Byte 09 > Bit 7 aktivieren („HC“, 1-coded)
> Byte 17 > Bit 0 aktivieren ("HC_messages,1-coded")
> Byte 17 > Bit 1-3 auf "02 Warning_intensity,Menu" setzen
> Byte 17 > Bit 5-7 auf "20 HC_Variante_1" setzen
STG 5F > Anpassung > …
> Kanal "Car_Function_List_BAP_Gen2-LDW_HCA_0x19" > Wert auf "aktiviert" setzen
> Kanal "Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus" > Wert auf "Datenbus Extended" setzen
> Kanal "Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning" > Wert auf "aktiviert" setzen
> Kanal "Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high" > Wert auf "aktiviert" setzen
STG 17 > Codierung > …
> Byte 04 > Bit 6 aktivieren ("Spurhalteassistent / Lane Assist verbaut")
> Byte 11 > Bit 1 aktivieren ("Spurhalteassistent / Lane Assist Information (BAP) verbaut/aktiv")
STG 44 > Zugriffsberechtigung: 19249 > Codierung > Byte 03 > Bit 0 aktivieren ("Spurhalteassistent verbaut")
hello lane assistt i did but 17 dials have errors? with obdeleven? giving databus error. also no orange marking on the dial 2020 superb
  • 4 months later...
Hello good,
My Superbe (delivered in August 2020) III Facelift 2020 has matrix Led, ACC, Light assist and signal recognition.
I guess it will have a highline camera and what it will be MY20.
I work with VCDS 20.12.0
I have tried this coding and the car tells me "Lane Assist not available". I have re-started the Infotaiment and the driving assistants
What is wrong?
What I can do?
How do I know what camera I have?
Is it MY20?
Thank you all
Without a scan it's impossible to say what is wrong.
If it's a genuine VCDS interface then update the software, the software has to be newer than the car (it can take Ross-Tech a few months for the software to catch up with the car.)
Look at the controllers to see if you have the A5 camera (it should be if you have TSR).
Pretty sure all facelifts are MY21
Edited by Gizmo
8 hours ago, Cesarpid said:
Hello good,
What is wrong?
What I can do?
Is it MY20?
Thank you all
You need to do a full scan and clear any errors flagged in the modification process
Thanks everyone for your help.
The VCDS is updated to the latest version.
The camera is 2Q0
Copy of module A5 reading
Dirección A5: Sensores frontales (R242) Etiquetas:* Ninguno/a/s
N°. de Parte SW: 2Q0 980 653  HW: 2Q0 980 653
Componente: MQB MFK 3.0 H11 1030
N° de Serie: E33417012201780
Codificación: 0002088811484028100500001030008001000000000000000000000000000000
Datos de ASAM: EV_MFK3ValeoMQB 005035
ROD: EV_MFK3ValeoMQB_005_VW27.rod
VCID: 72BDDAD5042CDF4B755-8026
without breakdowns
  • 5 weeks later...
On 09/05/2020 at 20:12, code_expert said:
I can help you with that contact me in Private message we can schedule the meeting via teamviewer
Hey all,
I have read here, on the forum, that it is possible to disable the super annoying noise generator, but sadly I have not been able to find any explanation how to do it.. Does it have to be done via VCDS or maybe VCP will be OK as well? I have currently access to VCP only, that's why I am asking. But.... if VCDS would be the only option, I think I will be buying one just for that :)
Please let me know.
Many thanks,
Kuba
my car: Skoda Superb iV 2019
Hi to anyone that can help.
I have a My21 Skoda Kodiaq RS. Just took delivery of it last week.
I'm trying to have the feature "Adaptive Lane Guidance" activated. I think it should be appearing under Lane assist once its activated.
Has anyone coded this feature or can help?
Thanks.
Welcome @Ronal
Can you add an autoscan from VCDS and ideally an adaption map from 5F? Without knowing what modules your car has, it's hard to offer advice :)
Hi @langers2k
Thank you.
I'm still waiting on my VCDS. from Ross Tech. Once i have it ill do that.
Ronal.
13 minutes ago, Ronal said:
Hi @langers2k
Thank you.
Ronal.
NO PROBLEM , WE CAN MAKE IT :)
  • 4 months later...
Hello.
Im wondering if any one has the instructions or solutions for coding the following items on an 2020 sportline.
Rear wiper - deactivated automatic operation / rain sensor, so you prevent automatic rear wiper when reverse. (needs to manually use the stalk instead)
Seat belt warning deactivation
Parking brake, auto off without seatbelt.
On 24/08/2021 at 16:37, Concker said:
Hello.
https://www.carscanner.info/
On 16/10/2020 at 19:39, code_expert said:
solutioon
Hello. Can you activate tja on the new 2q0 camera?
  • 2 years later...
Hi all😊😊😊
Is there a chance to change look on rpm gauge,so its more looks like a diesel car then petrol.For example like on normal instrument cluster for diesel.Car is Superb 2.0 tdi 200 with virtual cockpit.Thank you
Not sure if this will work as I haven't had chance to test on my new car but I was able to find out that in some cases there is difference in coding as follows:
Quote
For vehicles which have module 44 - Steering assist and VAG NUMBER - 5Q0 909 144 T. The coding is a bit different. You have to check Byte 0, Bit 4 Lane assist - Active
  • 9 months later...
Sorry to coming back to this post again, last time when I was trying to code lane assist using OBD11 I was having issues and only recently bought VCDS. I have it coded now and operational (not sure if fully) but there seems to be some other issues. I can't see option for Lane Assist on multicolour display on cluster to be able to enable/disable it (only ACC, speed limit, side, front and rear assist) also when enabled from options in radio all I have on cluster is orange/green icon on bottom of screen and no lines appear on multicolour part where you setup distance for ACC.
Another issue I have is that when I was working with OBD11 I must have somehow disable brightness adjustment for side assist - blind spot on radio. Anyone had similar issues and could help?
