Heated door mirrors....
Hope this doesn't fog up the issue any further:
Until 04/2002 the heater timer was 20 minutes - after this' date=' the default was untimed (always on when selected)
You can VAG-COM the timer settings for the heated mirrors:
Controller adjustment
STG 09 (electrical system) select
STG Login - > function 11
Note: Before the adjustment a Login has to take place.
Logincode: 21343
STG adjustment - > function 10
- > channel 003 (heatable outside mirror)
Disconnection time of the heatable outside mirrors.
Range of values: 1-253 = 0,66-173 min
Default value (to 04/02): 29 = 20 min
Default value (starting from 05/02): 254 (without disconnection)
Bas[/quote']
does this mean you can adjust the length of time the mirror is on ?
AFAIK this means you can adjust how long the mirror heater is on from when you select it -from 40 seconds to 173 minutes - or continous. (Default values are 20 minutes on up to 04/2002 and continous on from 05/2002 onwards.)
Same "controller" allows you to adjust timers for heatable windshield, rear window heater, how long you have to press the remote to unlock the boot, etc.
I used the same "controller" (with VAG-COM) but a different "channel" to increase the "highway comfort flasher"cycle (indicators flash when stalk is tapped) from 3 flashes to 4 - giving me a comfortable extra second to make sure there are no loony-tunes where I intend to be before changing lanes.
Bas:thumbup:
Odd - when I got my car (with the heater "on" setting at the top of the switch) I had to have a part replaced as the element had burnt out.
My dealer told me not to switch it on unless needed as it would burn the element out. I have got one of the early build Fabias, however...
Does the left hand mirror move in harmony with the right? The Golf used to do that I remember now, but not tried it on the vRS.
No it doesn't!!! :thumbup:
Or to be more explicit it does on early vRS's up to 09/04 but not on the facelift model (including mine) from 09/04
sorry didn't know they had deleted that feature ,mines a march 04 so it does adjust both:O
