Amundsen MIB2 Firmware Update
Is there any update for this software , Skoda Octavia III (2018 model).
  • Replies 4.6k
  • Views 775.3k
Wow.. what a quick response. Thanks @varooom!
Hello I like to know if there is any Updates for this one?
And if Is this the latest one: MST_EU_SE_ZR_P0479T?
Best regards Jesper.
The latest is actually 0369 that you can load, the 04xx versions are not compatible with your 03xx software train (0480 is latest in that "branch")
In theory you can load 0480, but not recommended as you could break your expensive unit.
Oh thanks!
No need for updating then!!
Oh thanks!
0359 -> 0369 sent via PM so technically there is an update
Can you add the language that does not exist?
Only what exists in the firmware can be used.
Hi, could I get the latest firmware update for the system bellow  please? Thanks and best regards!
Installed SW train version: MHI2_ER_SKG13_P4177
Installed SW MU version: 1125
Part number: 565035021A
Hardware: H54
Software version: H29.204.38_HIGH2GP_EU
Hardware: H54
Yes I can send version 1440
Hello,
I've done the update on my car last few months with a help of one of ours colleague here and after that I found on the tester diagnosis that I have an error of SVM, maybe someone can help me to fix this ?!?
Thank you.!!!
3 hours ago, varooom said:
THANK YOU SO MUCH 🍻🍻🍻
You're welcome, the fault doesn't affect unit, it's because it was not able to talk to the factory is all.
@varooom, can you also check if there is any update available for this unit? Much appreciate it! :)
Yes, exists this
S00.1000.17.99
release = "MHIG_EU_SK_K1552"
MUVersion = "0411"
22 minutes ago, varooom said:
Yes, exists this
S00.1000.17.99
MUVersion = "0411"
Are you able to provide me with this package? :)
Thanks in advance!
Thanks in advance!
Yes it's now compressing...
On 12/01/2023 at 12:05, varooom said:
Yes in a few minutes
I have updated succesfully via sdcard, tried first with usb drive - but it didn't work.
Thank you for your great work here.
Hello ,someone can help me for update ,that is my old version .Thank you in advance !
Yes, I can send MHI2_ER_SKG13_P4526  MU1440
p.s. Welcome to the forum
Thank you very much man ,i appreciate that!
Hello ,i install the update but are not all installed ,you know why ?I will try again with sd card ,last time i instaled them from usb ,maybe for that are not instaled all of them !
