Need a pic or diagram of fuses on elegance.
Wonder if anyone can take a pic of there 06 elegance 1.9 tdi fuse panel. I’m trying to work out what fuses are maybe missing or in the wrong place.
The manual is mirrored so tricky to follow also it seems to cover many models.
Edited by cypher007
It's pretty easy to spot missing fuses, there will be metal contacts at both ends ;)
someone could post you a photo of a pre FL mk2 RHD fusebox but the completeness will depend on how the options  match to your vehicle.  is there a problem you are trying to resolve?
Search internet for 'Skoda VIN decoder' to see all manufacturing options.
ill have a look for metal in the holes. good tip.
the manual is reversed guessing printed for European left handers.
I removed a 20A which says not used in the manual but heard a click under the dash so put it back. then noticed a load of errors for the central electronics or something. so im guessing the manual might be a bit off.
As someone mentioned before, elsewhere (one of your other posts I think) It's not a good idea to remove fuses in a  willy nilly fashion.
I learn't this years ago the expensive way with my Audi. Blown central convenience unit - stupidly trying to remedy airbag light....
Not a bad idea to answer TheClients question re - the problem you are trying to resolve......
If it is faults showing, I would suggest a scan, deleting any previously logged faults, and getting a fresh printout....
Edited by Tilt
To answer Theclient. I have recently bought the car and I'm finding quiet a few things have been fiddled with. Like the parking sensors that didn't work due to a misplaced fuse.
So hence why I'm making sure nothing else is a miss. Which is difficult when the manual is back to front and also seems to contradict actual fuses.
Edited by cypher007
@cypher007
Here's one I made earlier:
Need to double check but pretty sure I have a 20A in position 34 not assigned. When I remove it I can hear a relay under the dash click.
