2.0tdi 190 - resonance / drone around 2100 - 2200rpm
My car seems particularly noisy from about 2000 to 2200 rpm especially under light acceleration. Is regardless of gear and only really noticeable on the move.
Sounds like an air intake drone on the older vw PD engines but I can't see anything obvious.
Has anyone else experienced (or fixed!) similar?
Sorry, nothing similar on mine... Can't help you. 😐
Edited by Bap33
Yes it’s like a vibration. Mine does it sometimes but not always and it stopped for ages but now it’s back. Possible engine cover rubber worn
Is it a DSG? Could be a wearing dual mass flywheel (springs lose stiffness).
Edited by digifish
No a manual. It's definitely air intake area. And the air filter box is the source of the deep boomy noise but not what I'm on about 🙂
Mine does it .
It is brand new  MY2020 , 2.0 tdi with DSG7 190hp
there is some noise in 6th and 7th gear from 1600 to 2000rpm, under engine load.
I thing there is something plasic like engine cover, inder the hood,  that banging is some kind of metal...maybe .
I'm still searching for a soluton . Maybe is someting like this one , but i dindt find answer there.
https://www.briskoda.net/forums/topic/397349-engine-noise-vibration-and-harshness/
FWIW, I have a Superb III and when it was getting its 1st service I was given a Octavia (1.4 TSI 110 kw / 150 hp model with the 7 seed dry DSG)  loaner with 500 km on it.
This was significantly worse for vibration at idle than my (162 KW / 220 hp 2.0 TSI, 6 speed wet DSG) Superb and also had some noticeable vibration resonances at certain points in the rev range.
My superb is very smooth at idle and throughout the rev range. Impressively so for a 4 cyl.
Eye opener.
It's a diesel  😉
Think I’ve sorted mine. Exhaust heat shield. Runs the entire length of the car !! Had a fiddle with it and pushed and pulled a couple things and it’s shut up
Please,attach pictures if you have.
Just climb underneath and have a look mate. You’ll see it. Tapped along the length of it and it certainly made a vibration.
