Best Pressure washer?
Hi All
I’m after a pressure washer for a budget of around £250.
I've read reviews for the Karcher k4 and there’s a few good deals around at the moment but I’ve also come across models such as wills-USA on eBay which appear to be very powerful for not a lot of money.
what are people’s experiences and does anyone own a K4?
Generally looking at car cleaning with a snow foam lance and cleaning brick work and patios so it needs some power to suit.
Have a look at Nilfisk Pressure washers. They are very good value for the money.
Wait a few weeks and find a cheap Kranzle.
I'd echo that.
Had a few others including an stupidly expensive Karcher one and they have all bit the dust.
My current C130 was bought 4 years ago and is perfectly fine.
8 minutes ago, john999boy said:
I'd echo that.
Mine is a C130. I've had mine about 3 years. Excellent piece of kit.
I'll second (or 3rd, or 4th?) Nilfisk. They have metal impellers as standard so don't melt so much if run dry and should last a bit longer.
High pressure pumps don't use impellers, they might have a brass cylinder head rather than a plastic one though.
Actually this makes total sense.
I have had a couple of different Karchers which were ok but eventually gave up the ghost.
After doing quite a bit of research, Nilfisk came up as a worthy and better pressure washer replacement, which I subsequently bought from Cleanstore.co.uk.
The model I bought was a Nilfisk E145 which has performed admirably, whether in the garden or on the car, great pressure and performance.
Hope this helps you.
