Window Switch removal?
My window switch on drivers side vibrates like mad with any sort of bass and its annoying as hell. I want to try padding it out a bit, would this require the removal of the whole door card or is there a way to remove just the switch unit? If the door card needs removing, is it a pita?
The switch can be popped out using a trim tool. There's a single electrical connector underneath.
Are you sure it's the switch and not a wire rattling? I upgraded my mirrors to folding puddle lights and I didn't properly secure the wire to the mirror connector (on the passenger side) before reassembling. It nearly drove me bananas. Taking the door card off is easy enough with the correct tools - there's a guide on here somewhere.
Yeah pretty sure it's the whole assembly. If I just put my hand on it the vibration stops
  • john999boy changed the title to Window Switch removal?
Check here:
