Colombus issue - Happy to pay Eur 100 if someone fix my soft issue
On 01/05/2020 at 22:51, svenker said:
Hello,
Can someone help me please ?
I have:
Car: Octavia RS 2014
SW Train: MHIG_EU_SK_K1552
Sw Mu: 0411
Part numberL 5E0035020C
Soft Vers: 14.19.0_H15.17.1518_HIGH_EU
My previous Colombus had no sound anymore. I bought one ebay, I first had the issue of "protection components" and Skoda did fix this. (Now I have sound :-).
However, I have 3 errors: no ACC (front assist), Navigation data in the infotainement is not valid & cannot choose driving mode.
Any idea on how to fix this ? Skoda was struggling with this...
Thanks in advance for your help !
Sam
Hello, could anyone help me please ?
Actually I found a firmware online, was able to flash it and my part number became 5E0035020C when it was originaly 5E0035020A.
Honestly, if someone help me to fix it via VCDS (a teamviewer session) OR giving me the correct Firmware, I can wire up to Eur 100 for it ! Feel free to PM.
Thanks a million
Sam
The reason the navigation data is invalid is because you've fitted a unit which is not originally from your vehicle. Skoda should've been able to tell you this. There's no assistance with VCDS which will enable this.
Hi Petrol & Rusty,
I checked the forum and I can confirm I have the columbus. (sorry for not being clear in the other post).
Secondly, I bought exactly the same reference product on eBay but may be it comes from another car. Is it not possible to reinstall another firmware to get it to work on Octavia RS?
Thanks for your support!
Sam
For the navigation data issue, no. The others I don't know as there's no VCDS autoscan attached to your post so it's not possible to say what the issue might be.
Driving mode is likely a gateway issue, usually FeC related as is navigation but VW themselves don’t usually deal with retrofitted units but if the FeC for navigation hasn’t been enabled in the radio then it won’t work. ACC error seems unrelated so an autoscan is needed.
Hi SashaGrace & RustyNuts,
It is really wierd. The product reference on the MIB Unit (the broken one has the ref 5E0 035 020 A - H41) I was able to flash and it changed the Ref to 5E0 035 020 C...
Here is the AutoScan:
Thursday,07,May,2020,18:09:43:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: TMBJK7NE5E0100453   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 6D A9
VIN: TMBJK7NE5E0100453   Mileage: 116694km-72510miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUPA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7543
   Revision: 83H22---
   Coding: 111D0012036401080000
   Shop #: WSC 49797 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74E76AD2DFBB29E40C-8020
No fault code found.
Readiness: 0 0 0 0 0
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 J    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4027
   Revision: 05652104    Serial number: TFK01309271576
   Coding: 0014
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1E33687A01B7D3B40A-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 62873000000133
   Coding: 1C076B915420096C007B060541C62938D62A9000608294F4F6615070C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001
   ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod
   VCID: 7CF742F2F7EB61A444-8028
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02010104002100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 285F4EA253F31D0470-807C
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011329700357
   Coding: 0C001A46C24722FB0FA44004001C17280008000000000000000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77FD5DDECECD42FC29-8022
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131022  041 0570
   Serial number:         131026010436
   Coding: 065DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
   Component: RLFS  024 0042
   Serial number: Y13M10D24H23M08S23S1
   Coding: 02805D
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231329802027
   Coding: 0071051051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_002_AU37.rod
   VCID: 3B7581EEB265A69C0D-806E
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 11101376510695
   Coding: 000C1200FE0309
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 356197D6944170ECFB-8060
1 Fault Found:
1807 - No Enable Indentifications Active
          B2032 00 [009] -  -
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 18
                    Reset counter: 129
                    Mileage: 116636 km
                    Date: 2020.05.01
                    Time: 22:34:41
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 12.2 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0189
   Revision: --------    Serial number: 003P4PMN27AZ
   Coding: 98CCC000000000005C5400CC000800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 310 13
   Component: SideSensor_Df  008 0887
   Serial number: 3576U0000003E5B8FD0Y
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 001 310 13
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000455B8FD0R
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 710 13
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R85511B02000000W
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 710 13
   Component: SideSensor_Pr  111 0148
   Serial number: 3526R60CD1402000000
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 609 13
   Component: FrontSensor_D  114 0149
   Serial number: 3556VC964DF01000000O
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AQ    HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 22101308491513
   Coding: 6C00
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 050127168421206C2B-8050
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 871 F    HW: 5E0 920 871 F
   Component: KOMBI         333 2210
   Coding: 07A509082D80000801886A01000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 2B55B1AE4205361C9D-807E
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0001168090
   Coding: 030100040B087300EF00067A1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 009013
   ROD: EV_GatewLear_009_VW37.rod
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000B1415011013
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 8232921003
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000080226183
   Coding: 001D0820D000020000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 020B3C0A950F17540E-8056
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000965006
   Coding: 010200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
   Component: EPS_MQB_ZFLS  502 5011
   Coding: 8101
   ASAM Dataset: EV_SteerAssisMQB 009026
   ROD: EV_SteerAssisMQB_009_VW37.rod
   VCID: 3365A9CE9A356EDCD5-8066
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000080238393
   Coding: 001D0020D000020000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 0109330690090C4C17-8054
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000982073
   Coding: 190200
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0080
   Revision: --------    Serial number: --------------
   Coding: 03DA02003F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 3D718FF6AC71A8AC33-8068
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-HGH1.clb
   Part No SW: 5E0 035 020 C    HW: 5E0 035 020
   Component: MU-H-ND-EU    H41 0411
   Serial number: A313H0D7505747
   Coding: 03735201FF0000002111120100A800002F0001040100010076
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 173D7D5EEE8DA2FCC9-8042
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H50 0022
   Serial number: SKZ8Z9NL1007B5
   Data medium:
   Subsystem 2 - Part No SW: V03 959 800 MA    HW: -----------
   Component: ECE 2013/2014  --- 0062
   Serial number: --------------------
4 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 116636 km
                    Date: 2020.05.01
                    Time: 22:34:55
                    Voltage terminal 30: 12.5 V
                    System_Software_Error-SW_Status_Consistency: 00 20 00
                    System_Software_Error-SW_Status_DevName: E2pDab
2562 - Navigation System
          B126C F0 [008] - Navigation Database Faulty
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 169
                    Mileage: 116640 km
                    Date: 2020.05.03
                    Time: 16:00:11
                    Voltage terminal 30: 12.3 V
2571 - Navigation system
          B126C F2 [009] - Navigation database not enabled
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 116636 km
                    Date: 2020.05.01
                    Time: 22:34:44
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 125
                    Mileage: 116636 km
                    Date: 2020.05.01
                    Time: 22:34:46
                    Voltage terminal 30: 12.4 V
                    BAP-BAP_Function_ID: 02
Address 6D: Trunk Elect. (----)       Labels:| 7N0-959-107.clb
   Part No SW: 5E0 959 107     HW: 5E0 959 107
   Component: HDSG-Modul    H01 0744
   Revision: 42001001    Serial number: 277300778
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 69D90BA68879E40CAF-803C
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 131004200208
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X.rod
End-------------------------(Elapsed Time: 04:04)--------------------------
Thanks a million for your help !
Sam
Hi Rustynuts,
Impossible to do... without an official cable... I tried for 2 hours with differents Loaders etc but no success.
As I use the 18.2 version (2018) and the car is from 2014, it should be fine no ? I am able to remove errors, do longcoding changes & other tricks.
Any chance to help me out ?
