P2101 Throttle valve error, limp mode
I have Skoda Octavia 1.2 TSI from 2011.
The error actually appeared few moths back and I replaced the throttle body with new one (used original) and prefomed a Thorttle body alignment (TBA).
All went well until about 4 months later suddenly the ESP light and EPC icons light up on the dashboard. The car enters a limp mode where you barely can maintain speed. I have been driving the car using a Bluetooth OBD. By clearing the fault I can accelerate again until the fault appears again. It seems that if I hold the pedal still, it behaves good but once I need more power, the error comes back.
Address 01: Engine (J623-CBZB)       Labels: 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HT    HW: 03F 907 309 N
   Component: SIMOS10.12H03 5422
   Revision: --H03---    Serial number:
   Coding: 001900D6232400080000
   Shop #: WSC 73430 031 00085
   ASAM Dataset: EV_ECM12TFS02103F906070H 004006
   ROD: EV_ECM12TFS02103F906070BH.rod
   VCID: 7BF51167F210BBC6C11-802E
1 Fault Found:
10516 - Throttle Valve Actuator Control System
          P2101 00 [175] - Malfunction
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 7
                    Mileage: 193801 km
                    Date: 2099.14.04
                    Time: 11:56:02
Readiness: 0000 0000
So I inspected and cleaned the TB, all seemed OK. I then tried to do TBA again, but the VCDS says "Running" ... and then ... "Aborted-Safety reasons".
Now there is permanent error which cant be erased:
1 Fault Found:
11001 - Throttle Body (J338)
          P1559 00 [165] - Fault in basic settings
          MIL ON - Not Confirmed - Tested Since Memory Clear
Readiness: 0110 0101
Any ideas please how to fix it?
Just for your information. I was able to to perform TBA. The error could be erased for some time if you do idle RPM adjustment in VCDS. (I think it was Select ->Engine -> Adaption.) ( My Skoda talks UDS protocol). Then you need to exit the engine menu and go back again to starting page, then return (Slelect -> Engine) Make sure there are no fault codes and do the Throttle Valve adaption.
Once the P1559 error was gone I started trubleshooting the Throttle body. I taught the error could be somewhere else  since the error occurred with both throttle bodies I had (wiring, corroded ECU plugs etc). In the end it turned out to be faulty DC motor. So I combined the two faulty throttle bodies to make one good one. Next time it fails im gonna just buy new one.
Good result, sometimes it is better to buy new as you never know the status of the replacement part or indeed if it has the same fault!
