Low voltage at terminal 30
VAG-COM has flagged up an intermittent low voltage at terminal 30. This came up between fitting cruise and enabling it (2 days) so it could be related to that.
Where is terminal 30 ?
I'm pretty sure T30 is battery voltage.
What is the fault code?
Its a common foyble, it happens sometimes when you disconnect the battery. Just delete it, it'll not come back.
Fault code was 18010 but its not come back since I cleared it 15 miles ago.
