speed limit
can i turn off the speed going to fast on my 2018 skoda fabia  1.0mpi
Not sure there's an off option, but I set mine to max (which I think was 170mph). The setting is in the options menu.
there is no swichers for this on mine thanck
@ahancox
There is a way to set what you want a speed limit to be.
Has the car not got an owners manual you can read?
yes got owners manual but no operating lever to set speed
Nothing on the end of the stalk like a rocker, and nothing on speed limiter in the manual.
Does not sound like 'Simply Clever' from Skoda.
@ What speed does your it tell you that you are going too fast?
I think you are confusing the Speed Limiter with Cruise Control.
I'm guessing you do not have a Cruise Control, so there are no switches. The Speed Limiter sets the maximum speed that you can drive. This is adjusted in the car software setting in the main display.
If it is a 'Going too fast' warning look for the setting for that beside where you set the Speed warning for when Winter / Snow tyres are fitted.
There is that as well
My understanding is there are two different systems:
1. Speed limiter. This phyiscally stops you driving above a certain speed, unless you override it by pressing the pedal past the detent. However this does have controls on the left hand stalk, the same as cruise control.  Even on cruise control models you can switch between cruise or speed limiter. Cruise is different, in that it holds a speed without you pressing the throttle pedal. On some cars there is ACC where a radar also keeps your distance, but this isn't Standard on any Mk3 (AFAIK) and I don't think was even an option.
2. Speed warning. Set in the instrument pack as far as I know along with other trip computer options. Doesn't stop you going to fast but beeps at you if you exceed the set limit.
yes mine beeps if you exceed 3mph
no crews control
OK. So its speed warning. Either set from the central display, or by a menu in the instrument pack. Sorry can't remember which. Rather than switching off, you set the speed to something very high (I seem to remember). Have a look through the menus for speed warning. There's also one for winter tyres, as mentioned. You can turn that one off.
do u mean central display  betwene  spedo and revconter
will triy the one for winter tyres that in the radio thanks
its ok i have got it .you have to go into tyers  on  the radio scree  untick speed  then skroll down  to speed press button on right to set a speed like 150 thanks
