July 2017 FL SEL VCDS adaptations don’t work
Tail lights on with DRL
1 - Module 09 - Electronic. Code (31347)
2 - Adaptation
3 - Select – Leuchte 23SL HLC10
4 - Sub – Lichtfunktion D 23
5 - Change value to Tagfahrlicht (Daytime Running Light)
6 - Set Dimmwert CD 23 to 127
7 - Select – Leuchte 24 HRA65
8 - Sub – Lichtfunktion C 24
9 - Change value to Tagfahrlicht (Daytime Running Light)
10 - Set Dimmwert CD 24 to 127
The above VCDS /OBD Eleven  setting should enable what is known as Scandinavian Running Lights where the rear lights are on with the front daytime running Light. I can't remember which device I used to alter the coding but it worked ok on my car.
Edited by GUM213K
Typo
