SportLine radio screen
On 21/09/2020 at 10:04, SashaGrace said:
So I could have sworn the SportLine I had in a few weeks ago had a radio splash screen that said SportLine. That car was a 2017 with MIB2 Columbus. Not sure if this only affects the cars with Amundsen but apparently there are people out there who have SportLine Superb’s and the radio splash screen just has the normal ‘Welcome to Skoda’ screen like the late 2018 (MY19) car I had in yesterday.
So if this affects you, coding is 5F Byte 18 and you change the value from 8 to 13 in text mode, reset the radio and boom! SportLine splash screen. You’re welcome 😁
And 30 colour lighting with pre coding for RGB footwell lighting which is a retrofit that is coming soon!!
Hi Sasha, unfortunately on my superb sportline my17 with amundsen the obdeleven pro gives me error message in long encoding, I'll try again later in the morning.
Where can I find long coding for 30 colour lighting?
  • Replies 65
  • Views 24.3k
  • Unfortunately type 13 is not an option with Carista but I tried the others: Type none - welcome to Skoda (default on mine) Type 1 - vRS Type 2 - scout Type 3 - Laurin & klement
  • Yeah it is,   Go to 36 Drivers seat Long Coding and activate ‘Easy entry over MMI’ and then 5F Infotainment Adaptations in Car_Function_Adaptaions_Gen 2 and activate menu_display_drivers_sea
  • Got invited to beta test Carista again today after sending a debug log yesterday and they have added option 8 for the infotainment startup logo. just tried it and I now have the sportline startup
What BCM firmware do you have? Last MY17 I had in was on 0236 which is too old, you need 0242 or newer and if you have that, I can provide the coding.
Every firmware are radio will be different, perhaps only the MIB2.5’s have the SportLine splash screen in the firmware?
Think I have 0456
https://imgur.com/43L0fLP
RGB foot lighting you say... Would that be retrofittable to a MK3 Octavia?
edit:
Seems so...
Quote
The footwell lights are using same LIN like the doors do. It's the LIN5 in connector C on Pin29 of the facelifted BCM (Golf 7.5, Leon FL, Octavia FL...)
You have to replace the current connector of your footwell lights to the new 4 Pin connector and add the new wire for the LIN-Bus to Pin 3. ame procedure for the RGB footwell lights in the back. If everything is connected, start coding the new RGB lights and activate the new adresses of them: It's RGB LIN-User #14 and must be activated as "undefined14".
Things you need / Partslist'
Wires: 0,35mm² for LIN + MQS crimps
Front LEDs
1x 8W0947415A
1x 8W0947415B
Back LEDs
1x 8W0947415C
1x 8W0947415D
Connectors
4x 8K0973754A
Pin-out:
1: +
2: LIN
3: LIN (possible to use as output to right LED)
4: GND
Notice: it does not work on non facelifted MQBs or midline BCMs.
(otherwise replace BCM and retrofit a MIB2 with latest firmware)
Edited by langers2k
Think I have 0456
Thats the radio firmware, not BCM. But it’s an MY18 onward radio so you should be good. If in 09 adaptations you can find ambient light list 1 and 2 then you can do it. Pm me and I’ll send you my colour list.
edit:
Seems so...
Yeah if you have a 084DD or CG BCM then you can do it :D
I have:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
So if CG was a typo or being between CG and DD is suitable, I may have a chance.
Must stop planning retrofits, only had the car two days :D
5 minutes ago, langers2k said:
I have:
CQ is probably the software part number, the physical part number is CG but either way if it’s a 084 it’s doable. 086 ones aren’t.
You have the exact same file I have, 084CG 0253. Coding has taken, just waiting on the hardware.
I hadn't even noticed the SW and HW versions were different, noob moment ;)
Found these on VCDS diagnosis:
Indirizzo 09: Centrale elettr. (J519) Etichette:. ITT\5Q0-937-08X-V2.clb
N°. di Ricambio SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Componente: BCM MQBAB H H36 0253
N° di Serie: 01001715200420
Codifica: 000000000000000000000000000000000000000000000000000000000000 No Officina: WSC 33361 790 00159
Dati ASAM: EV_BCMMQB 018001 ROD: EV_BCMBOSCH_018.rod VCID: 09192823A8394BCE5D-805C
pm you later, thank you
You’re all good for 30 colours
I’ll just paste it below, you need to do this for the light colour list and LIN colour lists.
 Ambient light color list:
            Rotwert Farbe 1:
                255
            Gruenwert Farbe 1:
                0
            Blauwert Farbe 1:
                0
            Rotwert Farbe 2:
                230
            Gruenwert Farbe 2:
                0
            Blauwert Farbe 2:
                0
            Rotwert Farbe 3:
                242
            Gruenwert Farbe 3:
                80
            Blauwert Farbe 3:
                10
            Rotwert Farbe 4:
                230
            Gruenwert Farbe 4:
                100
            Blauwert Farbe 4:
                30
            Rotwert Farbe 5:
                230
            Gruenwert Farbe 5:
                160
            Blauwert Farbe 5:
                30
            Rotwert Farbe 6:
                255
            Gruenwert Farbe 6:
                190
            Blauwert Farbe 6:
                0
            Rotwert Farbe 7:
                230
            Gruenwert Farbe 7:
                230
            Blauwert Farbe 7:
                0
            Rotwert Farbe 8:
                210
            Gruenwert Farbe 8:
                238
            Blauwert Farbe 8:
                11
            Rotwert Farbe 9:
                210
            Gruenwert Farbe 9:
                255
            Blauwert Farbe 9:
                0
            Rotwert Farbe 10:
                170
            Gruenwert Farbe 10:
                255
            Blauwert Farbe 10:
                20
Ambience_lightning_color_list_2:
            Rotwert Farbe 11:
                60
            Gruenwert Farbe 11:
                255
            Blauwert Farbe 11:
                30
            Rotwert Farbe 12:
                0
            Gruenwert Farbe 12:
                235
            Blauwert Farbe 12:
                30
            Rotwert Farbe 13:
                0
            Gruenwert Farbe 13:
                235
            Blauwert Farbe 13:
                110
            Rotwert Farbe 14:
                50
            Gruenwert Farbe 14:
                255
            Blauwert Farbe 14:
                140
            Rotwert Farbe 15:
                0
            Gruenwert Farbe 15:
                225
            Blauwert Farbe 15:
                160
            Rotwert Farbe 16:
                0
            Gruenwert Farbe 16:
                225
            Blauwert Farbe 16:
                200
            Rotwert Farbe 17:
                0
            Gruenwert Farbe 17:
                200
            Blauwert Farbe 17:
                255
            Rotwert Farbe 18:
                0
            Gruenwert Farbe 18:
                160
            Blauwert Farbe 18:
                255
            Rotwert Farbe 19:
                0
            Gruenwert Farbe 19:
                120
            Blauwert Farbe 19:
                255
            Rotwert Farbe 20:
                10
            Gruenwert Farbe 20:
                90
            Blauwert Farbe 20:
                255
            Rotwert_Farbe_21:
                30
            Gruenwert_Farbe_21:
                40
            Blauwert_Farbe_21:
                255
            Rotwert_Farbe_22:
                65
            Gruenwert_Farbe_22:
                30
            Blauwert_Farbe_22:
                255
            Rotwert_Farbe_23:
                120
            Gruenwert_Farbe_23:
                30
            Blauwert_Farbe_23:
                255
            Rotwert_Farbe_24:
                195
            Gruenwert_Farbe_24:
                30
            Blauwert_Farbe_24:
                255
            Rotwert_Farbe_25:
                220
            Gruenwert_Farbe_25:
                0
            Blauwert_Farbe_25:
                255
            Rotwert_Farbe_26:
                255
            Gruenwert_Farbe_26:
                0
            Blauwert_Farbe_26:
                255
            Rotwert_Farbe_27:
                255
            Gruenwert_Farbe_27:
                0
            Blauwert_Farbe_27:
                115
            Rotwert_Farbe_28:
                255
            Gruenwert_Farbe_28:
                40
            Blauwert_Farbe_28:
                90
            Rotwert_Farbe_29:
                255
            Gruenwert_Farbe_29:
                90
            Blauwert_Farbe_29:
                70
            Rotwert_Farbe_30:
                240
            Gruenwert_Farbe_30:
                110
            Blauwert_Farbe_30:
                100
When keying those in a helper is useful, and be careful to save properly otherwise you have to start again. Guess how I know.
@SashaGrace thank you a lot
but first i have to fix a problem i surely caused with coding by OBDeleven.
I unlocked the off road informations (compass) but now the image of the car with the distances of the park pilot has disappeared from the maxi dot.
Think I disabled Optical Park System...
someone could help me?:sadsmile:
thank you
On 22/09/2020 at 17:39, SkudMissile21 said:
Also tried the instrument cluster start logo:
Type 1 - Skoda (default on mine)
Type 2 - vRS
Type 3 - Laurin & Klement
Type 4 - Scout
Type 5 - blank
Type 6 - sportline
Type 7 - Skoda
Type 8 - blank
I managed to change my cluster startup today using OBDeleven under long coding -> Start screen. It was default "Version 1" and changing to "Version 7" gave me the Sportline one
just tried it and I now have the sportline startup on there too B)
Brilliant!
SW version 1440 has a new option 9 for a second RS screen with a red logo
Also coded other goodies like the seat comfort access with working radio toggle
Sasha.. this is life changing stuff. Awesome. Mine is late 2016 but I’ll give it a go next week 👍🏻
2 hours ago, Chet said:
Brilliant!
That would be cool for the vRS owners out there, pity they never made a vRS superb but then I like my 280 4x4 much more than my old mk1 vRS octy :giggle: .
the only thing missing for me is the fact the instrument cluster shows the sportline logo on every startup but the infotainment only shows the logo on a hard reset and just goes straight to playing music on mine or am I missing a simple option like “splash screen every time” somewhere?
On ‎21‎/‎09‎/‎2020 at 09:04, SashaGrace said:
seat comfort access
This reminds me of Pheaton I used to own.
Such a cool feature, would love it operational on my Superb.
If you have electric seats it's a quick and simple job to activate via VCDS/OBDeleven.
Just to update on my previous comments regarding the infotainment not showing the logo it appears to be random some days it does show the nice sportline logo and other days it goes straight to playback, no idea why but at least it works so I’m very happy with this little mod. Thanks to SashaGrace for creating the thread as I may not have investigated it had I not known the option was available with a quick email to Carista (just a pity it’s only beta at the moment but hopefully it’ll make it to commercial eventually)
Dare I tempt you with custom boot animations 😂
Ha is this even possible??! I quite like the sportline one anyway and for the few seconds it’s displayed it’ll do me. I had a Kenwood upgrade in my last head unit that you could load custom images too and I just ended up with the standard “welcome to Skoda navigation” one..... boring but it looked the part!
MIB toolbox :D
I have a Bentley Breitling and TAG Heuer clock faces on my car using it.
Yep MIB toolbox, I just need to get better at graphic design to do something cool with it!
does MIB toolbox work on MIB2 Amundsen? I did know it was only for columbus 2.0 and superior
Pretty sure MIB2 toolbox only supports MIB2 high, aka the Columbus or discover pro.
People have asked for Amundsen/discover media but the developer doesn't have a device to test or time to add 😟
