Skoda Fabia 1.4 MPI Timing Chain
So, I've just changed the Timing Chain on my car, It was a bit of a pain, only because I didn't have a offset spanner and there isn't room to get a socket in there (trip to Halfords sorted that)
to stop the crank and cam spinning while undoing these I had someone apply the breaks hard,
Its all back together with 12 chain links between the 2 sprockets as stated in the Haynes, I had to use a gasket glue (Granville high temp black instant gasket) for the Sump! -  as theres no gasket for this car
which i didn't realise takes 24 hrs to cure!! Joke!!
So I'm eagerly waiting till tomorrow to see if I've still got a car!
If all goes well, I'll post a decent step by step right up with photos exactly how its done, as I've struggled to find any decent info, other then a polish video on YouTube.
24hrs!?! joke lol, Doing nothing for my nerves
Oh also garage quoted me £300, multiple garages
chain kit £28.
If all goes well gonna do the water pump next week, looks easy the hardest part will probably be the clips on the pipes (I've seen a tool on amazon £13 like pilers with a bike cable.. should make it easier)
Edited by MinkyMike
  • Sponsor
Do it. One of the best tool purchases I've ever made.
It sounds to me like you have no reason to be anxious about the outcome of your work.  :)
hehe thanks mate, i did a Peugeot 106 years ago, and must of been out by one tooth, because it sounded like a gun! (been dreading any timing work ever since)
got to say this was an easier process but I think this engine is probably one of the easiest to do? there so close together and it only links 2 sprockets..
thanks! i did try removing these clips (water pump) with mole grips, but there really isn't room.
if car ok tomorrow I will buy for sure :)
Edited by MinkyMike
So, I started it up and it started fine, so I didn't mess the timing up, however it still sounds the bloody same, rattling chain sound.. seems like it's coming from that same direction of the new chain.. I give up, least I know it's had a new one, but for it being quiter, it ain't.. unless it's something else making the noise... Can't really see how I would of not done it right, it's like 1 bolt after all..  Nightmare !
Edited by MinkyMike
I'll try get a video up on YouTube of the noise maybe someone else might have an idea .
From what I've heard of mine mate it's normal for these engines I get it sometimes but only once weather starts getting colder in summer nothing lol.
Ah it's all sorted now mate it turned out to be a water pump bearing, although the chain might of been making a noise as well , the car has done 120k and the chain was pretty stretched, quiet as a mouse now, apart from knocking when going over speed bumps ! That's my next job , bushes?? Lol
Mine is on 70k and the chain rattles at idle, so yours will have definitely been rattling. I found that fitting the sound dampening pad on the underside of the bonnet from a vRS model helps to supress the noise coming into the cabin quite a bit. Most of the time I don't notice it now.
Edited by TMB
