Roomster airbag warning light switched off??
After removing & replacing the passenger airbag (to replace blower motor resistor), the airbag warning light is on (not flashing). When switching on the ignition, the warning light comes on, goes off for a second, then comes on again, which according to the manual means that the passenger airbag is switched off.
I have double checked the airbag connector. My model does not have the switch which allows you to turn off the passenger airbag.
I'd be very grateful for any suggestions!
  • Sponsor
This generally happens if the ignition is switched on whilst the airbag is disconnected.  Needs VCDS to clear the fault I believe.
Thanks Wino. I'm not aware of having done that, but you never know!
My resistor pack has to be replaced as speed 1 has gone. It is recommended to disconnect the battery whilst doing so. Are there any problems caused by the disconnection of the battery?
I'm a complete novice at this stuff, and the only problem I had was the airbag warning light issue (above). I haven't got it reset yet so I can't advise on that. Otherwise fine.
