Mib 2 high and 2.5 high SW update
Hello, maybe someone can help with upgrading Amundsen to newer firmware than I currently have. It is now MST2_EU_SK_ZR_P0252T
  • Replies 143
  • Views 86.5k
  • There are 2 versions of Columbus:- - MIB2 with buttons on the side - MIB2.5 without buttons (from MY18 onwards)   Mine is MY17.
  • SkudMissile21
    SkudMissile21
    Just a word of warning to anyone here doing a diy firmware upgrade, it seems it’s possible you may end up with a fault code logged that cannot be cleared afterwards (Carista lists it as “01555 motors
  • VCDS CODING 5F (Infotainment) module, Adaptations, channel: 'Confirmation of installation change' Note your current coding Start Windows calculator and set it to 'Programming mode' and select 'HEX'
MST2_EU_SK_ZR_P0253T_V0020171002.7z This is last availiable one that you can install without any tricks, but with some tricks you can upgrade up to MST2_EU_SK_ZR_P0478T.7. All instruction and FW you can find here
Thanks, managed to upgrade to 0253, but how to upgrade to 0478 doesn't allow writing to an older version. or I do something wrong.
You didn't read my answer fully, i mentioned that it is impossible to switch from one series to another without some tricks, as i mentioned full instruction could be found in MEGa link was provided before you need to modify some files, some post you can see, here and here and here articles how change SW or region. I don't have MIB stn i can't provide you detailes, i did only for mine MIB 2.5 high.
hello
stupid question but whether after upgrading from MST2_EU_SK_ZR_P0252T to MST2_EU_SK_ZR_P0253T after a few days I can't start the machine. Currently not running start engine does not turn on the ignition. I changed the button because the service thought it was a problem, but nothing has changed since the change. Everything works in the KESSY system except the engine ignition is not switched on.
On 12/12/2020 at 11:10, Donatasmi said:
hello
Definitely problem not in your MIB, you need to find good service. There are numbers of people who already change FW for MIB no issue at all. Do diagnostic.
@RomanB
do that all risky maneuvers can add Web Radio option in Columbus 8" (no SIM; no DAB+) Mib2?
    Device part nr: 3V0035043B
    Hardware:    H50
    Installed SW train version:
        MHI2_ER_SKG11_K2129_2    (dealer update 2017.09.28)
        MHI2_ER_SKG11_K3333    (dealer update 2018.05.11)
        MHI2_ER_SKG11_K3343    (dealer update 2020.01.21)
    Installed SW MU version:
        0318    (factory)
        0848    (dealer update 2017.09.28)
        1233    (dealer update 2018.05.11)
        1433    (dealer update 2020.01.21)
    Software version:
        H25.14.78_HIGH2_EU    (dealer update 2017.09.28)
        H28.28.202_HIGH2_EU    (dealer update 2018.05.11)
        H28.28.210_HIGH2_EU    (dealer update 2020.01.21)
    Media Codec:
        CLU4_MMX2_SK_ER_G11_047PROD-1    (factory)
        CLU6_MMX2_SK_ER_G11_145PROD-1    (dealer update 2018.05.11)
        CLU6_MMX2_SK_ER_G11_147PROD-1    (dealer update 2020.01.21)
    Bluetooth version:
        10.326.780    (factory)
        10.376.331    (dealer update 2017.09.28)
        10.446.287    (dealer update 2018.05.11)
    MirrorLink version:
        CLU4_SK11ER_047    (factory)
        CLU4_SK11ER_053    (dealer update 2017.09.28)
    App-Connect:
        CLU4_SK11ER_053    (dealer update 2018.05.11)
    Radio database version:
        1.8.3    (dealer update 2018.05.11)
Yesterday i tried to open this new feature in dealer's Tarraco, no luck
Not so much important for me right now, just interesting.
i have found almost perfect alternative for Android phone
FMPlay
1. no commercial popups
2. can add own links
3. stations can be switched from steering wheel
4. playback starts by self when press [MEDIA]
5. playback stops by self when press [RADIO]
6. huge customizing field in favorite section - count of displayed columns, change order by press, hold and move
7. no buffering delay on switching stations
11 hours ago, MartiniB said:
@RomanB
    Hardware:    H50
        0318    (factory)
    Software version:
    Media Codec:
    Bluetooth version:
    MirrorLink version:
    App-Connect:
FMPlay
so do you want to add DAB radio? as i know it is hardware and you can't just solder some extra stuff, so best way use any online radio from your Phone.
@RomanB
DAB isn't new feature,
and yes, depends on hardware and not all countries brodcast it
Asking about Web Radio aka i-net radio
3 minutes ago, MartiniB said:
@RomanB
No any guess, I have never try
I have Amundsen 5Q0035864B MIB2 SW 0367 and want to update to newer version. Version MST2_EU_SK_ZR_P0253T_V0020171002.7z right for me? Thanks!
NO, all devices MIB2 standart must be in the same set of FW like if you have 02xx you can update it to 02yy for instance  from 0252 to 0253 device itself will not allow you update it to 0366 as for instance, if you want to update to 03xx or 04xx you need to apply some tricks all instructions could be found on MEGA. As i can see you have already installed last availiable FW for this device.
Edited by RomanB
hi please give me new link the mib 2.5 thanks
My car is vw touran. this link is good?
Which file its ok?
1 hour ago, palipalesz said:
Which file its ok?
Try to download mu1427 check metainfo2 file there is support trains list if yours train in this list go ahead, if not check lower version.
And which the MIB 2.5 ?
Which part isn't clear? You can see your train mhi2 so open mhi2 folder then chose vw if it so then you train vwg11 any fw but my recommendation check highest one each fw contains metainfo2.txt file there is support train list. So you need just check is your fw in this list if it so go ahead, if not check lower version. So as i mention previously you need to use MHI2_ER_VWG11_K3342_MU1427 it supports (SupportedTrains = "MHI2_ER_VWG11_P3250*,MHI2_ER_VWG11_P3301*,MHI2_ER_VWG11_K3332*,MHI2_ER_VWG11_K3342*")
Edited by RomanB
Can anyone point me in the right direction for updating this guy?
https://mega.nz/#F!r9tC3ABC!Y-HVkemvshkcSn3vWMauOw!jktw0KaQ unzip to root of SD file MHI2_ER_SKG13_P4526_MU1440.7z then update, don't copy folder with name MHI2_ER_SKG13_P4526_MU1440 you need to copy files from it to root directory of your SD card
Edited by RomanB
Cheers, got it downloaded. I’m assuming this is just an update file and won’t require anything to be setup again such as car play or Skoda connect?
Nothing, except 1555 FW update error (could be found while scanning) could be easily deleted by odis VSDC obd and so on, rest of function will be the same.
Edited by RomanB
