Alternative to keep pulling fuse
Changed the standard stream HU a while back for the Bolero, Didn't change the can bus (too much faff), Is there anything i can do apart from keep pulling the radio fuse so i don't end up with a flat battery. Like i say don't want to replace the can bus because of sourcing a correct one and cost. Already tried switching the earth wire to the radio which doesn't work...Thanks..
I am unfamiliar with your setup but why switch the earth instead of live?
Run a switched live for the headunit?
Yes, change the canbus and get it coded. Why mess about with wiring, fuses etc when it's a known, documented procedure to fix the issue
 Why tell the Op to do something that they have said they do not want to do and they have given their reasons. why they don't want to???
Just curious why someone would do this.
Ive always switched earth in the cars ive had in the past when putting a switch in line for something,, Just that when plugging the aerial in the back of unit it uses that as an earth.
@Doofy
Exactly, so switch the live.  Electronics can sometimes find an earth through an unintended route.
If yours is a 2005, is a really simple job to swap the canbus gateway, as it's behind the glovebox.
I got mine for £20 on ebay when I upgraded my HU. Keep searching and one will come up at a reasonable cost.
Will that one be ok with the 'Q' prefix, Mines an 'F' ?
Took the plunge and bought it,  Got it for £12.50 so cannot grumble, Thanks everyone.
Remember to take a copy of the coding of your old unit while it its still connected and to recode the new one the same.
It solved my current draw problem with an aftermarket head unit on a 2006 Octavia so I am confident it will do the same for you if you bought the correct revision number.
I cant recall what is the minimum revision letter to resolve the problem, Q is a lot later than F so you will probably be alright, Google will tell you, it will most likely be a Rosstech web page.
Edited by J.R.
