Handling problem
:confused:
A bit advice peeps if you would. Ive recently noticed that, under hard acceleration, the front left wheel pulls and skips. It is too pronounced to be torque steer, even skipping about when the road is dry - i would like some suggestions to give to my dealer so as to give them some sort of idea as to what im talking about when i get time to contact them. Thanks all.
Blown damper?
Also get them to check the wishbone bushes as they can fail. Other options? Wheelbearing?
Daft question...
I assume you've actually checked for loose wheel bolts?..
You never know ;)
KW time.
Wheel bounce is a problem with the RS the KW's will feel a lot better.
Des
