Steering Angle Sensor and ESC Errors etc.
Hi! Having some trouble with my car after - doing stuff i should not have.
Either way tho I have tried 15 times to reset the Steering Angel Sensor using the prerequisites from Vag-Com driving in a straight line and so on. Without any success.
- I'm also getting error from the dash saying proactive passenger safety thing error not working. And the parking sensors is not working (getting the beep but not the reverse lines and no response from rear sensors.).
The Log of the module error Below Using OBDELEVEN for the log and coding:
Quote
Date: 2020-11-07 17:09
VIN: TMBAC9NE1E0198907
Car: Skoda Octavia
Year: 2014
Body type: Saloon
Engine: CHPA 103 kW (140 HP) 1.4 l
Mileage: 178074 KM
01 Engine
System description: 1,4l R4 TSI
Software number: 04E906016G
Software version: 6185
Hardware number: 04E907309A
Hardware version: H08
ODX name: EV_ECM14TFS01104E906016G
ODX version: 002009
Long coding: 01250032232401080000
Trouble codes:
U112300 - Databus error value received
static
03 Brakes
System description: EMB8 EHCB
Software number: 5Q0907379R
Software version: 0356
Hardware number: 5Q0907379F
Hardware version: H31
Serial number: 60754000000A32
ODX name: EV_Brake1UDSContiMK100ESP
ODX version: 033001
Long coding: 1A076A91242911740080060041CA245856248800608224F0002100004002
Trouble codes:
B116854 - Steering angle sensor No basic setting
static
U112200 - Databus implausible message
static
42 Driver Door
System description: TSG FS
Software number: 5Q4959593B
Software version: 0014
Hardware number: 5Q4959593B
Hardware version: 009
Serial number: 0000096652244
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Long coding: 001741007E00049400830A00
Subsystems:
System description: FOND_FHSG_DRV
Software version: 0005
Hardware version: 005
Serial number: 00000000000002136224
Long coding: 010200
Trouble codes:
B129F29 - Child Safety Lock Switch Implausible signal
static
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144P
Software version: 1043
Hardware number: 5Q0909144P
Hardware version: 122
ODX name: EV_SteerAssisMQB
ODX version: 010031
Long coding: 890A
Trouble codes:
static
55 Headlight Regulation
System description: AFS-ECU
Software number: 7P6907357D
Software version: 0090
Hardware number: 7P6907357A
Hardware version: H07
Serial number: --------------
ODX name: EV_HeadlRegulVWAFSMQB
ODX version: 001120
Long coding: 030A00003D000000
Subsystems:
System description: LeiMo links
Software version: 0009
Hardware version: H06
Long coding: 3E0000
System description: LeiMo rechts
Long coding: 3E0000
Trouble codes:
static
76 Parking Assistance
System description: PARKHILFE 4K
Software number: 5Q0919283B
Software version: 0033
Hardware number: 5Q0919283
Hardware version: H09
Serial number: 60831408101829
ODX name: EV_EPHVA14AU3700000
ODX version: 002018
Long coding: 0000000011
Trouble codes:
static
My Questions:
- My question is how is it possible to fix this?
- Should I do something in another order?
Thanks in advance!
Edited by Guest
  • Guest changed the title to Steering Angle Sensor and ESC Errors etc.
What stuff did you do that you should not have?
Some things can only be reset by a factory connection (e.g. where a configuration file has been deleted/overwritten) but others can be sorted out by reversing the coding/adaptation changes and possibly running some recalibration functions - to know which applies here we need to know exactly what you did.
I did replace the brake pads around the car. And then did a reset of the steering angle sensor in basic settings. And also did a reset of the brake settings. I do have the history down here. Have tried like 100 different methods that's why its so long.
Steering Angle History
Quote
Datum: 2020-11-09 11:02
    VIN - fordonets serienummer: TMBAC9NE1E0198907
    Bil: Skoda Octavia
    År: 2014
    Kroppstyp: Saloon
    Motor: CHPA 103 kW (140 HP) 1.4 l
    Mätarställning: 178108 KM
Lång kodning
    Kontrollenhet: 44 Steering Assistance
    Gammalt värde:
        8902
    Nytt värde:
        890A
    Mätarställning: 178074 km
    Datum: 2020-11-07 17:02
Lång kodning
    Gammalt värde:
        0002
    Nytt värde:
        8902
Grundinställning
    Namn: Steering angle sensor
    Status:
        active
    Datum: 2020-11-07 17:01
Grundinställning
    Namn: Steering angle sensor, initialization
    Status:
        active
        Basic setting ended
    Mätarställning: 177788 km
    Datum: 2020-10-13 13:36
Grundinställning
    Status:
        active
    Datum: 2020-10-13 13:35
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 13:34
diagnos session
    Värde: VW - diagnostic mode
Grundinställning
    Namn: Steering angle sensor, move to mechanical center
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 13:33
diagnos session
    Värde: End of assembly line mode (EOL)
Grundinställning
    Status:
        active
        Basic setting ended
Grundinställning
    Status:
        active
    Datum: 2020-10-13 13:12
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 13:09
diagnos session
Grundinställning
    Status:
        active
        Basic setting ended
Grundinställning
    Status:
        active
    Datum: 2020-10-13 13:08
Lång kodning
    Gammalt värde:
        2902
    Nytt värde:
        0002
    Datum: 2020-10-13 13:05
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 13:04
Grundinställning
    Namn: Resetting of all adaptation values
    Status:
        Basic setting ended
    Datum: 2020-10-13 13:03
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 13:00
Grundinställning
    Status:
        active
Grundinställning
    Namn: Software end-stop reset
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 12:53
diagnos session
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:52
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:48
Grundinställning
    Namn: Reset to factory setting
    Status:
        Basic setting ended
    Datum: 2020-10-13 12:46
Grundinställning
    Namn: Resetting of all adaptations
    Status:
        Basic setting ended
Grundinställning
    Status:
        active
Anpassning
    Namn: Download without rest bus
    Värden:
        Suspension data bus:
            Gammalt värde: active
            Nytt värde: not active
    Datum: 2020-10-13 12:44
Anpassning
    Namn: Driving profile switchover
    Värden:
            Gammalt värde: Direct, controlled over threshold value
            Nytt värde: Incremental, controlled over time
    Datum: 2020-10-13 12:43
Lång kodning
    Värden:
        Pull compensation:
            Gammalt värde: Active, with learned value
            Nytt värde: Active, without learned value
        Driving profile selection:
Lång kodning
    Gammalt värde:
        A502
    Nytt värde:
        2902
Lång kodning
    Gammalt värde:
        A500
    Nytt värde:
        A502
Lång kodning
    Värden:
        Parallel parking assistance:
    Datum: 2020-10-13 12:42
Lång kodning
    Gammalt värde:
        A700
    Nytt värde:
        A500
Lång kodning
    Gammalt värde:
        AB00
    Nytt värde:
        A700
    Datum: 2020-10-13 12:41
Lång kodning
    Gammalt värde:
        A900
    Nytt värde:
        AB00
Lång kodning
    Värden:
            Gammalt värde: not active
            Nytt värde: active
Lång kodning
    Värden:
        Electronic Stability Program:
        Steering angle sensor:
            Gammalt värde: internal
            Nytt värde: external
Lång kodning
    Gammalt värde:
        8902
    Nytt värde:
        A900
Anpassning
    Namn: Characteristic curve of steering assistance
    Värden:
            Gammalt värde: Automatic
            Nytt värde: Dynamic
    Datum: 2020-10-13 12:40
Anpassning
    Värden:
            Nytt värde: active
Anpassning
    Värden:
            Gammalt värde: Incremental, controlled over time
            Nytt värde: Direct, controlled over threshold value
diagnos session
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:39
diagnos session
    Datum: 2020-10-13 12:37
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:36
diagnos session
    Datum: 2020-10-13 12:33
diagnos session
diagnos session
diagnos session
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:32
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 12:30
diagnos session
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:29
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-13 12:27
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:24
Grundinställning
    Status:
        active
    Datum: 2020-10-13 12:20
Grundinställning
    Status:
        active
    Mätarställning: 177355 km
    Datum: 2020-10-03 16:11
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-03 16:10
Grundinställning
    Status:
        active
    Datum: 2020-10-03 16:02
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-10-03 16:01
Grundinställning
    Status:
        active
    Datum: 2020-10-03 16:00
Grundinställning
    Status:
        active
    Mätarställning: 177314 km
    Datum: 2020-09-28 12:59
Grundinställning
    Status:
        active
        Basic setting ended
Lång kodning
    Värden:
            Gammalt värde: external
            Nytt värde: internal
            Nytt värde: active
    Datum: 2020-09-28 12:58
Lång kodning
    Gammalt värde:
        2902
    Nytt värde:
        8902
Lång kodning
    Värden:
Lång kodning
    Gammalt värde:
        0902
    Nytt värde:
        2902
    Datum: 2020-09-28 12:57
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
    Mätarställning: 177301 km
    Datum: 2020-09-27 15:39
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-09-27 15:36
Grundinställning
    Status:
        active
    Datum: 2020-09-27 15:35
Grundinställning
    Status:
        active
    Datum: 2020-09-27 15:31
Grundinställning
    Status:
        active
    Datum: 2020-09-27 15:01
Grundinställning
    Status:
        active
    Datum: 2020-09-27 14:57
diagnos session
    Värde: Development mode
    Datum: 2020-09-27 14:53
diagnos session
Grundinställning
    Status:
        active
    Datum: 2020-09-27 14:52
Lång kodning
    Värden:
        Pull compensation:
            Gammalt värde: Not activated
    Datum: 2020-09-27 14:50
Lång kodning
    Gammalt värde:
        0102
    Nytt värde:
        0902
Lång kodning
    Värden:
        Counter steer support:
            Nytt värde: active
Lång kodning
    Gammalt värde:
        0002
    Nytt värde:
        0102
Grundinställning
    Status:
        active
    Datum: 2020-09-27 14:40
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-09-27 14:39
Grundinställning
    Status:
        active
    Datum: 2020-09-27 14:37
Grundinställning
    Status:
        active
    Mätarställning: 175789 km
    Datum: 2020-09-11 12:27
Grundinställning
    Status:
        active
    Datum: 2020-09-11 12:26
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-09-11 12:23
Anpassning
    Värden:
            Nytt värde: active
    Datum: 2020-09-11 12:16
Grundinställning
    Status:
        active
    Datum: 2020-09-11 12:15
Grundinställning
    Status:
        active
        Basic setting ended
    Datum: 2020-09-11 12:14
Grundinställning
    Status:
        active
    Datum: 2020-09-11 11:46
Grundinställning
    Status:
        active
    Mätarställning: 175784 km
    Datum: 2020-09-10 20:02
Lång kodning
    Gammalt värde:
        8902
    Nytt värde:
        0002
    Datum: 2020-09-10 20:01
Grundinställning
    Status:
        active
    Datum: 2020-09-10 19:59
Grundinställning
    Status:
        active
    Datum: 2020-09-10 19:58
Grundinställning
    Status:
        active
    Datum: 2020-09-10 19:57
Grundinställning
    Status:
        active
    Datum: 2020-09-10 19:55
diagnos session
    Datum: 2020-09-10 19:52
Grundinställning
    Status:
        active
    Mätarställning: 175781 km
    Datum: 2020-09-10 18:11
Grundinställning
    Status:
        active
    Datum: 2020-09-10 18:06
Grundinställning
    Status:
        active
    Datum: 2020-09-10 18:05
Lång kodning
    Värden:
            Nytt värde: active
    Datum: 2020-09-10 18:04
Lång kodning
    Gammalt värde:
        0902
    Nytt värde:
        8902
Lång kodning
    Värden:
        Pull compensation:
            Nytt värde: active
Lång kodning
    Gammalt värde:
        0002
    Nytt värde:
        0902
Lång kodning
    Gammalt värde:
        890B
    Nytt värde:
        0002
    Mätarställning: 175773 km
    Datum: 2020-09-09 21:16
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:13
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:12
Grundinställning
    Status:
        active
        exited due to reasons of safety
        Basic setting ended
    Datum: 2020-09-09 21:11
Lång kodning
    Värden:
Lång kodning
    Gammalt värde:
        A90B
    Nytt värde:
        890B
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:09
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
Lång kodning
    Värden:
    Datum: 2020-09-09 21:08
Lång kodning
    Gammalt värde:
        890B
    Nytt värde:
        A90B
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:07
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:06
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:05
Grundinställning
    Status:
        active
    Datum: 2020-09-09 21:00
Grundinställning
    Status:
        active
    Datum: 2020-09-09 20:59
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
    Datum: 2020-09-09 20:57
Grundinställning
    Status:
        active
        Basic setting ended
    Mätarställning: 175755 km
    Datum: 2020-09-05 16:07
Anpassning
    Värden:
    Datum: 2020-09-05 16:06
Anpassning
    Värden:
    Mätarställning: 174814 km
    Datum: 2020-08-18 13:32
Anpassning
    Värden:
            Nytt värde: active
    Mätarställning: 170937 km
    Datum: 2020-05-12 15:21
Lång kodning
    Värden:
        Pull compensation:
    Datum: 2020-05-12 15:20
Lång kodning
    Gammalt värde:
        810B
    Nytt värde:
        890B
Anpassning
    Värden:
            Gammalt värde: Driving profile selection button
            Nytt värde: Automatic
    Mätarställning: 168125 km
    Datum: 2020-04-02 10:21
Anpassning
    Värden:
    Mätarställning: 160588 km
    Datum: 2019-11-09 11:35
Lång kodning
    Gammalt värde:
        038E01003F030000
    Nytt värde:
        810B
    Mätarställning: 157590 km
    Datum: 2019-08-27 12:39
Lång kodning
    Gammalt värde:
        810B
    Nytt värde:
        038E01003F030000
    Mätarställning: 157165 km
    Datum: 2019-08-21 18:16
Lång kodning
    Gammalt värde:
        090B
    Nytt värde:
        810B
    Mätarställning: 156620 km
    Datum: 2019-08-07 23:00
Lång kodning
    Värden:
            Nytt värde: active
        Ramp behavior at engine stop:
            Nytt värde: active
    Datum: 2019-08-07 22:57
Lång kodning
    Värden:
        Pull compensation:
            Gammalt värde: Active, without learned value
            Nytt värde: Not activated
Lång kodning
    Värden:
    Datum: 2019-08-07 22:55
Lång kodning
    Gammalt värde:
        0903
    Nytt värde:
        090B
Lång kodning
    Gammalt värde:
        8903
    Nytt värde:
        0903
Lång kodning
    Gammalt värde:
        B103
    Nytt värde:
        8903
Lång kodning
    Värden:
Lång kodning
    Värden:
        Pull compensation:
    Datum: 2019-08-07 22:54
Lång kodning
    Gammalt värde:
        A102
    Nytt värde:
        B103
    Mätarställning: 156466 km
    Datum: 2019-08-06 20:03
Lång kodning
    Värden:
        Lane assistant:
            Nytt värde: active
    Datum: 2019-08-06 19:58
Lång kodning
    Värden:
            Nytt värde: active
diagnos session
Anpassning
    Värden:
            Nytt värde: active
    Datum: 2019-08-06 19:57
Anpassning
    Värden:
            Nytt värde: Default
Anpassning
    Värden:
    Mätarställning: 156451 km
    Datum: 2019-08-05 22:02
Lång kodning
    Gammalt värde:
        8102
    Nytt värde:
        A102
    Mätarställning: 156331 km
    Datum: 2019-08-04 01:32
Lång kodning
    Värden:
    Mätarställning: 156302 km
    Datum: 2019-08-03 13:34
Anpassning
    Värden:
            Gammalt värde: Dynamic
    Mätarställning: 155109 km
    Datum: 2019-07-06 23:52
Anpassning
    Värden:
            Nytt värde: active
Anpassning
    Värden:
    Mätarställning: 153373 km
    Datum: 2019-06-11 16:17
Anpassning
    Värden:
    Mätarställning: 151185 km
    Datum: 2019-05-09 11:43
Anpassning
    Värden:
            Nytt värde: active
    Datum: 2019-05-09 11:42
Anpassning
    Värden:
    Mätarställning: 148653 km
    Datum: 2019-04-07 04:02
Lång kodning
    Gammalt värde:
        0102
    Nytt värde:
        8102
    Mätarställning: 137615 km
    Datum: 2019-01-09 21:17
Lång kodning
    Värden:
            Nytt värde: active
    Mätarställning: 137329 km
    Datum: 2019-01-04 10:20
Anpassning
    Värden:
Anpassning
    Värden:
    Mätarställning: 135667 km
    Datum: 2018-12-20 23:35
Anpassning
    Värden:
Anpassning
    Värden:
    Mätarställning: 135559 km
    Datum: 2018-12-19 12:15
Anpassning
    Värden:
    Mätarställning: 135488 km
    Datum: 2018-12-18 22:22
Brake History:
Quote
    Bil: Skoda Octavia
    År: 2014
    Kroppstyp: Saloon
diagnos session
    Kontrollenhet: 03 Brakes
    Datum: 2020-10-13 13:28
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Namn: ASR and ESP function deactivation
    Status:
        active
    Datum: 2020-10-13 13:27
diagnos session
    Datum: 2020-10-13 13:26
diagnos session
diagnos session
    Datum: 2020-10-13 13:25
diagnos session
    Datum: 2020-10-13 13:16
Grundinställning
    Namn: Basic setting of ESP sensor unit
    Status:
        Basic setting ended
    Datum: 2020-10-03 16:09
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Namn: Basic setting for inlet/cut-out valves
    Status:
        active
        Basic setting ended
    Datum: 2020-10-03 16:08
Grundinställning
    Status:
        active
        cancelled due to detected malfunction
Grundinställning
    Status:
        active
Grundinställning
    Namn: Erase counter for start and stop processes
    Status:
        Basic setting ended
    Datum: 2020-10-03 16:07
Grundinställning
    Status:
        active
Grundinställning
    Namn: Shut off longitudinal acceleration monitoring
    Status:
        Basic setting ended
    Datum: 2020-10-03 15:58
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Status:
        Basic setting ended
Anpassning
    Namn: Vehicle and trailer stabilization
    Värden:
        Trailer information evaluation:
            Gammalt värde: activated
    Datum: 2020-10-03 15:57
Anpassning
    Namn: Expanded electronic differential lock
    Värden:
        Electronic Differential Lock:
            Gammalt värde: Standard
Anpassning
    Namn: Starting vibration reduction
    Värden:
        Starting vibration reduction:
            Gammalt värde: Strong
            Nytt värde: normal
Lång kodning
    Gammalt värde:
        1A076A91242911740080060041CA245856248800608224F0002100004001
    Nytt värde:
    Datum: 2020-10-03 15:56
diagnos session
    Datum: 2020-10-03 15:55
diagnos session
    Datum: 2020-10-03 15:54
diagnos session
    Datum: 2020-10-03 15:50
diagnos session
    Datum: 2020-09-28 12:53
diagnos session
    Datum: 2020-09-28 12:51
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-28 12:45
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-28 12:44
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 15:25
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 15:18
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 15:17
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 15:02
Grundinställning
    Namn: Basic setting for brake pressure sensor
    Status:
        Basic setting ended
    Datum: 2020-09-27 14:59
diagnos session
    Datum: 2020-09-27 14:58
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 14:45
diagnos session
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-27 14:43
Lång kodning
    Gammalt värde:
        000000000000000000000000000000000000000000000000000000000000
    Nytt värde:
    Datum: 2020-09-11 11:42
diagnos session
    Mätarställning: 175787 km
    Datum: 2020-09-11 11:35
diagnos session
    Datum: 2020-09-11 11:33
diagnos session
    Datum: 2020-09-11 11:32
diagnos session
diagnos session
diagnos session
    Värde: OBD-diagnostic mode
Grundinställning
    Namn: Reset to factory setting of tire pressure monitoring display
    Status:
    Datum: 2020-09-10 20:17
Grundinställning
    Status:
        active
Grundinställning
    Status:
        active
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-10 20:16
diagnos session
    Datum: 2020-09-10 20:12
diagnos session
    Datum: 2020-09-09 21:18
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-09 20:52
Grundinställning
    Status:
        active
diagnos session
    Datum: 2020-09-09 20:51
diagnos session
    Datum: 2020-09-09 20:49
diagnos session
diagnos session
    Mätarställning: 175768 km
    Datum: 2020-09-08 16:10
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-08 16:09
diagnos session
    Datum: 2020-09-08 16:06
diagnos session
    Datum: 2020-09-08 15:57
diagnos session
    Datum: 2020-09-08 15:49
Anpassning
    Värden:
            Nytt värde: Maximum
    Datum: 2020-09-05 16:05
diagnos session
    Datum: 2020-09-05 15:46
Lång kodning
    Gammalt värde:
        1A076A91242911740080060041CA245856248800608224F0002100000001
    Nytt värde:
    Mätarställning: 175751 km
    Datum: 2020-09-05 14:34
diagnos session
    Datum: 2020-09-05 14:33
Grundinställning
    Status:
        Basic setting ended
    Datum: 2020-09-05 14:32
Grundinställning
    Status:
        Basic setting ended
Grundinställning
    Status:
        Basic setting ended
diagnos session
    Mätarställning: 174271 km
    Datum: 2020-08-06 18:24
Lång kodning
    Gammalt värde:
    Nytt värde:
    Datum: 2020-08-06 18:22
diagnos session
    Mätarställning: 174264 km
    Datum: 2020-08-06 11:23
Anpassning
    Värden:
            Nytt värde: medium
    Datum: 2020-08-06 11:22
Anpassning
    Värden:
            Gammalt värde: Maximum
            Nytt värde: normal
    Datum: 2020-08-06 11:17
Anpassning
    Värden:
            Nytt värde: medium
    Mätarställning: 171497 km
    Datum: 2020-05-24 19:34
diagnos session
    Datum: 2020-05-24 19:33
Anpassning
    Värden:
            Gammalt värde: normal
            Nytt värde: Maximum
    Mätarställning: 170666 km
    Datum: 2020-05-06 07:28
Lång kodning
    Gammalt värde:
        913F200E09230501891004EC9021A050A1080021
    Nytt värde:
    Mätarställning: 170294 km
    Datum: 2020-05-01 14:07
Anpassning
    Värden:
            Gammalt värde: medium
            Nytt värde: Strong
    Mätarställning: 168332 km
    Datum: 2020-04-06 16:20
Anpassning
    Värden:
            Nytt värde: Standard
    Mätarställning: 162450 km
    Datum: 2019-12-11 17:41
diagnos session
    Datum: 2019-12-11 17:40
Anpassning
    Värden:
            Nytt värde: medium
    Mätarställning: 162150 km
    Datum: 2019-12-04 11:12
Anpassning
    Värden:
            Nytt värde: normal
Anpassning
    Värden:
            Nytt värde: Maximum
    Mätarställning: 160692 km
    Datum: 2019-11-10 14:46
diagnos session
Lång kodning
    Gammalt värde:
        1A076A91242911740080060041CA245856248800608224F0002100004003
    Nytt värde:
    Datum: 2019-08-05 22:03
Lång kodning
    Gammalt värde:
    Nytt värde:
    Datum: 2019-08-05 21:57
Lång kodning
    Gammalt värde:
        0C04134742C622FB47801004001C430B00C8000000000000000000000000
    Nytt värde:
    Datum: 2019-05-09 11:48
Anpassning
    Värden:
            Nytt värde: Strong
Lång kodning
    Gammalt värde:
    Nytt värde:
    Datum: 2019-05-09 11:47
Anpassning
    Namn: Electronic Stability Program
    Värden:
        Speed-dependent activation:
            Nytt värde: activated
    Mätarställning: 137232 km
    Datum: 2019-01-03 18:16
diagnos session
    Mätarställning: 136680 km
    Datum: 2018-12-27 08:41
Anpassning
    Värden:
            Nytt värde: Maximum
    Datum: 2018-12-27 08:40
Anpassning
    Värden:
            Nytt värde: normal
    Datum: 2018-12-18 22:31
