Starting problem with 2015 TDI
Hello. I'm new here and in a spot of bother.
My Fabia 1.4 TDI wont start. It turns over for a second on the starter then stops. It's one of the stop/start engines so keeping the key all the way won't keep the starter going.
It did this once before but started OK after a few tries.
I'm stuck in a carpark so any help much appreciated.
P.
Thanks Wino I'll have a look. No tools with me.
It started at last after I fully depressed and released the accelerator pedal. I didn't expect that to work, assuming that the computer would ignore it.
However, this was after 30+ attempts over a 2 hour period. Was it just coincidence?
P.
I have the 2015 1.2 petrol version. Could not start car it felt like only 2/3 cylinders were firing. Rang green flag guy got in car 2 seconds later car started. He said i had flooded the carb. Can happen if car moved a short distance when cold which is what i had done the evening before.
A bit embarasing after driving for 55 years Joe
Carb? Surly fuel-injected, no carburettor!
