Replacing Front Springs
I will adopt that phrase Mac!
  • Replies 53
  • Views 13.2k
  • According to gknautomotive.com there are four different front springs for the Skoda Octavia MK2 hatchback 1.6TDI depending on whether the car has sports or standard springs, and whether the car has ma
  • So that part number in my ebay link is the right one, first one that @Carlston listed above - 1K0411105AQ
  • Kilen 25061 and Lesjofors 4095079 are the same spring and made in the same factory in Sweden. They are both an identical replacement for OEM part number 1K0411105AQ or at least they should be as Kilen
10 hours ago, MRB007 said:
84.05 Euros plus VAT is about £180 for both front springs, and that doesn't include shipping.
The Sachs 993044 are £68 for both front springs on ebay including postage.
The following brands are listed on autodoc with only OEM part number 1K0411105AQ being shown so they might be a close copy of the original in some cases:
Borsehung
Denkermann
Eibach
Febi Bilstein
IPSA
JP-Group
Kilen
KYB
Lesjofors
Magnum
Maxgear
Optimal
Sachs
Spidan
Stark
Suplex
SWAG
Triscan
TRW
However, many of these brands I suspect will come from cheap Chinese factories producing goods of dubious quality. Caveat emptor as they say in Latin.
https://www.autodoc.co.uk/car-parts/oem/1k0411105aq?search=OEN+1K0411105AQ&supplier[0]=112&supplier[1]=4815&supplier[2]=383&supplier[3]=101&supplier[4]=10018&supplier[5]=10180&supplier[6]=85&supplier[7]=253&supplier[8]=11006&supplier[9]=10721&supplier[10]=129&supplier[11]=32&supplier[12]=100001&supplier[13]=10708&supplier[14]=108&supplier[15]=833&supplier[16]=246&supplier[17]=1&supplier[18]=1156&supplier[19]=108&supplier[20]=833&supplier[21]=1&supplier[22]=100001&supplier[23]=129&supplier[24]=10721&supplier[25]=11006&supplier[26]=85&supplier[27]=101&supplier[28]=383&supplier[29]=4815&supplier[30]=10180&supplier[31]=112&supplier[32]=10018&supplier[33]=253&supplier[34]=32&supplier[35]=10708&supplier[36]=1156&supplier[37]=246
Edited by Carlston
Lesjofors are made in Sweden where they know a bit about steel & coilwinding.
I paid €21 each in August of this year.
Qparts24.de
Edited by J.R.
 Lesjofors 4095079 looks like a good choice for the front springs on the Skoda Octavia MK2 1.6TDI with manual gearbox. They match OEM part number 1K0411105AQ. Available on ebay for £18 each if you buy two.
https://www.ebay.co.uk/itm/Coil-Spring-fits-VOLKSWAGEN-EOS-1F-1-4-Front-07-to-15-Suspension-LESJOFORS/133500092506?epid=11035121187&hash=item1f1539c05a%3Ag%3AaIMAAOSwaKJfQSvd&LH_ItemCondition=1000
Edited by Carlston
Just called a main dealer £216 inc VAT for the pair!!!!!
  • Sponsor
Yeah, when I linked to that ebay ad showing a genuine spring, it was just to show you the paint marks, not as a suggestion of what to buy.
We know genuine VW group springs aren't as good as they used to be, cos they keep breaking!
Broke my wallet!
I've used Kilen springs before and they are same quality as original at fraction of the price and still rust free after 5 years.
As long as you match it to the Kilen parts catalogue to your car you will be fine.  I only fitted one front spring and it was a perfect match as I know you are suppose to replace them in pairs for best results but I didn't have an issues.
Contacted this sellor about there Kilen springs and the model that I had found using the OEM part number was wrong.
They suggest that I use the following springs
We do have the correct part you need which can be found here:
KILEN COIL SPRING FRONT LEFT 14124
http://www.ebay.co.uk/itm/333730617419
KILEN COIL SPRING FRONT RIGHT 14125
http://www.ebay.co.uk/itm/333778732094
  • Sponsor
Very odd. The OE springs are the same on both sides, so why would aftermarket ones be different?
Edited by Wino
Maybe because they are springs for a Honda & they use handed ones?
The Lesjofors cross references are also different part numbers.
@J.R. That's because I was a **** Head and put the wrong reg down when I sent them an email.
Good Spot SIR!!!!!
I have contacted them and shall report my findings once I get a reply
:D:D:D
How lucky for you that you posted the link!
  • Sponsor
Just about to edit my last post that cast aspersions on the ebay seller!
Edited by Wino
Kilen 25061 and Lesjofors 4095079 are the same spring and made in the same factory in Sweden. They are both an identical replacement for OEM part number 1K0411105AQ or at least they should be as Kilen/Lesjofors both match them to OEM part number 1K0411105AQ and no other part number.
Edited by Carlston
7 hours ago, pmdc199 said:
I just ordered Bilstein shocks and coils. mine is VRS so sports suspension. But other VAG sites swear by Bilstein.
I suspect in many cases, Bilstein shock absorbers are actually Lesjofors/Kilen.
If for example, a Skoda Octavia MK2 1.6TDI hatchback has rear springs with OEM part number 1K0511115BE then the Bilstein 36-134076 rear shock absorbers is used to replace both OEM part numbers 1K0511115BE and 1K0511115BF. Bilstein 36-134076 can't match both these OEM numbers because they have different specifications, with 1K0511115BF being slightly heavier duty than 1K0511115BE. Kilen 63117 and Lesjofors 4285718 both have the same one size fits all approach. Spring manufacturers do this to save money. It's cheaper for them to make just one spring that they can sell to replace more than one specification of spring.
However, Sachs 994414 is sold to replace OEM part number 1K0511115BE and no other OEM part number. This means that it's probably the same specification as OEM 1K0511115BE.
Sachs replacement rear springs for OEM part number 1K0511115BE
https://www.autodoc.co.uk/car-parts/oem/1k0511115be?search=OEN+1K0511115BE&supplier[0]=32&supplier[1]=16&supplier[2]=246&supplier[3]=253&supplier[4]=246&supplier[5]=16&supplier[6]=253
Edited by Carlston
Interesting, I was going to put Sachs springs on mine. I have them for is rear. Then I ordered the Bilsten to compare them next to each other.The Bilsten are still on route.
The Sachs is 994454 - oem 1K0511115BS which is only for Skoda VRS estate. Plus fits some Golf 6’s.
where as the Bilstein are only for the RS
36-199655, (maybe fits other cars but thats all that they list)
The Sachs is 994454 - oem 1K0511115BS which is only for Skoda RS estate. Plus fits some Golf 6’s.
Kilen's online coil spring catalogue lists the Skoda Octavia MK2 RS hatchback as having rear spring OEM number 1K0511115BS and the estate as having rear spring OEM number 1K0511115BT
Many aftermarket springs are sold to replace both these OEM numbers, so that you would end up having the same rear springs whether you had the hatchback or the estate version of the Octavia MK2 RS.
If you have an Octavia MK2 RS hatchback, it might also be worth considering OEM number 1K0511115BQ for the rear springs, as according to the gknautomotive.com online catalogue the 1K0511115BQ version is 9mm shorter than the 1K0511115BS/1K0511115BT version, with everything else such as thickness and number of coil turns being the same. The estate is probably a little heavier at the back than the estate, so using estate rear springs on a hatchback would raise the ride height.
You can access the Kilen online coil spring catalogue here:
https://www.kilensprings.com/springs-catalouges/onlinecatalogue.asp
If you are interested in OEM number 1K0511115BQ for the rear springs on your Octavia MK2 RS, avoid Bilstein, Kilen, Lesjofors, and KYB. These brands think that it's OK to sell the same aftermarket spring to replace both OEM number 1K0511115GC and 1K0511115BQ. These springs have a very different spring rate, with 1K0511115GC having a 11.25mm thickness and 1K0511115BQ having a 11.75mm thickness.
Optimal and Sachs springs that are sold to replace OEM number 1K0511115BQ are listed as having 366mm length. This I suspect is incorrect, and should be 321mm in length. Fortunately, it's easy to measure a new coil spring with a tape measure to within a few millimetres. Before fitting a pair of new springs, always check length, thickness, diameter, weight, number of coil turns, and make sure they are a matched pair. They should weigh within a few grams of each other if they are a matched pair.
Edited by Carlston
you are good. I found that out too yesterday. The Bilstein lists it as BT part ending. That’s why I want to physically compare them.
But even the drawings on the vw catalogue lists more spring codes.
I also wonder what the technical difference is between the coils for estate and hatch back.
Are the estates a larger diameter?
