Skoda Scala SEL White & Black
the diffuser look amazing I was also not impressed by the diffuser as it was not aggressive enough. Top job DIY'ing it your self. also boot install looks clean
  • Replies 55
  • Views 33.1k
  • Quick little update New rims! TSW Sebring 19x8.5j with Goodyear Eagle F1 Asym 6 225/35/19 Wanted something as unique as the Scala and really pleased with how they look and sit.
  • New Update, Longlife Cat-Back exhaust, Maxton Design Front Splitter V1, Side Skirts with custom mounting into front mud guards, rear bumper trim painted in Piano gloss black to get rid of that ch
  • Recently I created my own custom diffuser for the Scala.  Main reason for this is that I bought the Maxton Design rear Valance to fit to the stock lower bumper panel, and it didn't fit flush and had a
Hi Steve I’ve been looking at some of your pics and the car looks fantastic. I am planning on some of the mods and I agree the car is sat a little high. I would be looking to lower 15 to 20mm. Could this be achieved with just springs using the oem dampers? Or will I need new dampers to achieve this. Any advice would be appreciated.
Cheers
Cheers
Hi Dave,
Just springs will be fine for that look at Eibach or H&R
Hi thanks for that, I wasn’t sure wether the oem dampers would be ok. You mentioned in one of your posts how the lowered springs had damaged them.
Dave
Dave
I had Eibachs, lowering 30mm all around, for about 6 months.  They were a good spring and gave a much better look and handling to the car.  With my setup, the more modifications I did I personally felt as though the dampers went a bit soft with time.  Now, that could be the case but it could also be just my perception as I was desiring a stiffer and more sporty ride.  Ultimately both Eibach and H&R test their lowering springs with stock dampers and sell them to be used in that manner, it is only when looking at their marketed 'sport' springs that they suggest uprated dampers.
  • 5 months later...
