over heating Skoda octavia 2014 mk3 tdi 150bhp
i have a mk3 2014 skoda octavia 150 bhp overheating
new water pump and cambelt
and thermostat.
ps its ex ambulance service
all genuine parts used
still boils over temp upto 130 degrees
cools down with heater on full
so any ideas please
any special way it needs bleeding
any help appreciated
i wonder coolant temp sensor is faulty ?
also water bottle is pressurise ing
Can you confirm that the radiator fans are switching on or not please?
I've heard interesting stories that the cable loom is messed around with and certain random functions stop working.  Can you also check your fuses to see if a fuse as popped - and try to also get a VCDS scan (for faults codes).
yes fans come but dont seem to cool unless i put the heaters on.
i have vagcom so can do that.
no lights on dash.
the blue light system is wired completely seperate to the car.
they just take a feed off the canbus system.
my mate fits these systems.
havent checked fuses but everything else works perfect.
they obviuosly had an issue with it systems are water pump but its had one.
ive got a coolant temp sensor coming from tps tomorrow.
if it isnt that i dont know.
will vcds later.
Does the main radiator get hot right to the bottom.
If not, could be the thermostat is stuck shut or only opening a little.
been replaced got a brand new one from tps !
no lights on dash.
will vcds later.
vcds just on engine mangement
no fault code found !
Sounds like there might be an airlock somewhere. Id try the test bleed function a few times to see if that circulates the coolant around.
yeah thats what it seems like how do i do that with vcds ?
need a video on how to do it with vagcom.
and thats the old engine i can bleed those.
this either is a pressure bleed.
or computer bleed.
although im going to check the plastic gromit in the vent tube.
Does it warm up normally as you would expect? also you say the expansion tank seems to be pressurising. how quickly does it do this. Just thinking out loud if it seems to warm up and pressurise it may be head gasket that has gone
As skodavia has said, if you think the pressurisation is any more than normal coolant expansion, then it might be time to arrange a sniff test to confirm or exclude HG failure.  If it is compromised then any pressurisation from the combustion process is likely to add to any air lock woes.
Gaz
it sort of warms normally but the guage isnt reading right i dont think.
the pressure is probably normal.
 its just its obviuosly a bit hot !
possibly due to airlock.
i have bought a temp sensor from tps.
it doesnt have any head gasket symptoms but if i dont sort the issue then im sure thats the danger !
i think it needs a pressure bleed or doing with vagcom which i have.
but i need someone to tell me how.
these mk3 cr 150 dont bleed like the 140 cr different process
as these have 2 auxillary pumps aswell as belt driven solenoid pump.
although i think i may have ot sniffed tested for piece of mind.
  • Sponsor
Check for residual pressure in the expansion tank when the engine is stone cold.
ok al go check now
checked no residual pressure and its cold.
  • Sponsor
That's good.
just a quick update thanks to youtube !
i found the top vent pipe that comes from the top hose to the T piece with the grommet was blocked so dug it out vuala ! can now blow thru it.
snag is the plastic tube off the black cap on the block is broken.
so tps are sending me the bits tomorrow.
so think the problem is solved so it was an air lock !
will post tomorrow when ive bled the system.
fingers crossed chaps !!
and thanks for the replies.
quick update.
still the same.
ive found that the rad is cold.
but i have put a brand new thermostat in it.
unless its faulty.
so this is why it is boiling up air locked and not cooling.
although vent pipe was blocked.
  • Sponsor
Take the stat out and see if problem disappears.
cheers wini
will do
the old one doesnt open either checked it in a jug.
will let you know later.
hi guys
removed thermostat
now heaters cold.
radiator cold
temp guage says 90
so water def isnt circulating
thermostat housing is hot to touch
pipe to rad cold
so i have a blockage
wonder if silicat bag in expansion tank has burst and caused a blockage ?
Any ideas
much appreciated
Have you run the separate pumps via vcds to get the coolant moving?
  • Sponsor
Test the removed thermostat in a big pan of boiling water?
Seems to me that if removing it solves the overheating, then it may be the problem?
