Just a coincidence? Rear wiper, rear tailgate lock & reg number plate lights not working...
Hi All
Just wondering if any one has had this problem?
All of a sudden, my rear wiper, my boot release, rear registration plate lights (and possibly my rear heated window) have all stop working at the same time? I am wondering if this is down to the constant rain we had for the last two weeks. I am hoping it will dry out and fix itself, but I am wondering if it is something more serious?
I don't think it is fuses (what's the chance of 3 going at the same time?)  but it feels like it is electrical. Any advice where to start looking first would be great.
My rear interior lights and the rear window washer is working fine - I am just trying to pinpoint the issue.
Any help would be gladly received.
Paul
My guess would be broken wire(s) within the trunking at the top of the tailgate.
These have been known to fail with repeated opening and closing of the tailgate.
Had a similar problem earlier this year, boot wouldn’t unlock, wiper became intermittent etc
Had to have the tailgate wiring loom replaced.  Seems the quality of wiring used in in the Roomster is of dubious longevity where it flexes at top of tailgate
Hi Robjon and SurreyJohn for replying to my post.
I am going to investigate tomorrow once I have got the lock open from the inside...
There is a breakers yard not too far away from me with a Roomster, I may pay a visit if it is fairly easy to swap out a wiring loom unit.
I will let you know how I get on.
If different elctrical items are broken all together in one section, it could be coincidental the supply pinched for all of them or the earth is loose or broken.
Here is my update on the situation.
Eventually worked out how to manually open the boot. Loosened off the electrical loom to discovered a couple of broken wires, I also moved the trim on the tailgate and on c pillar to work out what wires went where. Created a bridge with wire and connector blocks for each broken wire to see if I could get any response.  The main brown wire that was snapped was working again, so rear wiper, heated windscreen, brake light, reg plate lights are all working again. The other bridged broken wire (with the brown one) goes to the tailgate does not work, try a few things but it will not pop open off the fob. If I need to open the boot i have to go in through the rear passenger doors.
I have got the car road legal again - (reg plate lights are a MOT fail) then noticed my rear wiper wasn't working properly as well, so I am in the process of replacing the wiper arm, just waiting for parts.
So with a heavy heart, I have made the decision to get rid of my Roomster in the spring. Over the last couple of years I have replace electric window switches, rear bumper sensors, repaired and refilled air con gas, replace heating resistor, repaired the front windscreen wiper linkage and it needs four new tyres and a new battery and possibly a rear wiring loom.
  • 4 weeks later...
Replacing the heating resistor?  was this because you had very little control over the temperature the heater was blowing out?
Like 3 clicks and it was blasting full sahara desert?
if it was I have this issue, could you post a prt number for the part that fixed it?
What I can remember, it was either off or full blast.
The part I needed I got off Amazon https://www.amazon.co.uk/gp/product/B01MDLZN9H/ref=ppx_yo_dt_b_asin_image_o05_s00?ie=UTF8&psc=1
It was quite a fiddley job, disconnect battery, take out glove box, remove airbag, replace part (need small hands!) Put back together and you might need to clear Air bag warning lights from dash using VAG COM software and laptop cable. https://www.ebay.co.uk/itm/OBD2-Diagnostic-Scanner-Cable-Tool-For-VW-Audi-Seat-Car-VAG-COM-KKL-409-1-NEW-/383889304706?hash=item596195ec82
I watch this YouTube video online, which was a great help.
Good luck, I hope this all helps.
Thats awesome, thanks for replying :)
