Slowed to a crawl - WHY?
my 'old' PC - a P4 1.6 with about 800MB ram - has suddenly gone very slow.
All it does is fold! I never use it for anything else and all it has on it is Norton and folding.
It's been working on the same WU for a couple of days now... yesterday it was taking about 90 mins per 'bit'; today it's been taking about 4 hours per bit! And as I say, it's the same WU.
I've run a virus check and that's not come up with anything.... anyone got any ideas what it might be?? :confused: ??
My XP2200+ has been going 5 days on one.... :(
I think that FAH has recently handed out some seriously BIG units. :thumbdwn: and my machine isn't coping well with it.
at this rate, it would take my pc 400 hours to complete this one WU!! And I don't think that's right somehow, as the WU is 'only' worth 404 points.... prior to this sudden slow down it was working through it at about 1% every 90 mins or so. now, it's 1% every 4 hours or so!
Thing is I can't find anything 'wrong' that would explain why getting up to 13% took 90 mins per %, and then 13-14 took 240, and 14-15 took 240, and 15-16 took 240! :confused: :confused: :confused:
tried a reboot?
yup, tried a reboot, twice...
is there anything anyone can see in the taskmanager that shouldn't be there??
Looks fine :)
Overheating CPU?, full of dust maybe?
guess it could be overheating, now that the warmer weather is here.... having said that, there are about 5 fans in the case, and I've stripped out a lot of 'unnecessaries' in there (2 redundant CD writers, one redundant HDD, one redundant RAID card) so there should be a lot more room in there now which should in turn mean the airflow should be a lot better?
Guess I'll just have to leave it be for a while - if it doesn't get any better I'll stop it folding, delete the WU, and see how it gets on with a new one :)
Another good thing that EVERYONE should have as part of their task manager...
CPU time....
go to view menu and select colums.. choose the cpu time.
This gives a good indication if theres something munching a wee more cpu cycles than they should..
the FAH should be the biggie..
yup, just looked and FAH is 25:34:54... next closest thing is svchost.exe on 00:02:15
maybe it IS just a massive WU then..... :confused:
CPU time....
:thumbup: Never seen that before in task manager
Most things around 2 or 3 minutes, internet explorer about 20 minutes.... FAHcore.... 60 HOURS! :rofl:
How do you join the folding team at briskskoda.
I have a large farm of DualCore Xeons doing nothing for the next week ;)
EDIT: worked it out, but it seems like a complete pain to set up multiple clients on multiple multi core machines. ph well havn't got time to be doing that at the moment.
EDIT: worked it out' date=' but it seems like a complete pain to set up multiple clients on multiple multi core machines. ph well havn't got time to be doing that at the moment.[/quote']
Follow the link in my signature. If you need any detailed info on setting up the FAH as a service in windows XP - drop me a PM. ;)
Edit: And as a service its easy peasy - You just need to have two clients running, and in the command prompt setup, 1 machine is given ID 1, and the other ID 2. Alternatively just download the graphical client and run at 50% of total capacity (every little helps. :thumbup:
well you have two 4 way boxes running at 50%, one all the time the other when it's on :) Should hopefully have that fora week or so ;)
Can't you forget to uninstall? :rofl:
I'm currently "Stress testing" the cooling on the boxes... see how long it takes ;)
At some point a small farm of about 10 of these will need to be tested, however I wouldn't think it would be me doing it, but somebody who is actually part of the test team ;)
The GUI currently claims 7.3s per frame.
Now the better question is does anyone work in an university department. The one i used to work in was doing the cancer folding, had about 1000 new machines running it at idle, 24/7 365. THe amount that churned out :)
We've yet to find that magic Briskodian who has hundreds of machines to dispose spare CPU to our cause. :D
