USB ports current?
Anyone knows how much amps the USB-C ports give?
Are the (optional) ports at the back the same as the front?
I did not find this information in the manual.
Edited by john999boy
Updated title.
29 minutes ago, xerces8 said:
Anyone knows how much amperes the USB-C ports give?
The back ports are for charging only, the front are charging and media, no idea on amps
  • john999boy changed the title to USB ports current?
Yeah, I am interested in knowing the amps too,as my S20fe is having a real hard time charging when plugged in, it barely gains 10% per hour. And wandering how to solve this issue.
I checked a few cables, including original and to no avail
Put an app like accubattery on the phone and monitor charging time / current. sounds like the max charging current is pretty low. Not sure how you would fix that.  Maybe plumb your own connection, or the wiring back from the ports, but seems a bit out of expectation with a new car!
At 15w it should be a bit more than 1.5 hours full charge. so that is 15 min 10%.
Of coure adaptive fast charge will be up to 45w and that is 3 x as quick.
10% in 1 hour on a 4500mah cell pack seems very slow indeed. Should be about 15 min even on non adaptive charging...
Edited by TheClient
  • 2 months later...
I just tested the front USB-C port with a phone and the Amperes Lite app (it gives good estimates with most chargers) and it is about 17W, while the phone supports 18W (USB-PD standard).
So it has at least 18W (the current itself is not informative, as the voltage also changes).
