1.6 TDI anti roll bar size.
Hi all, just looking to double check what size the Anti roll bar is on my Monte Carlo. I'm planning on replacing the drop links and d bushes to tighten up the front of the car and I want to make sure I have the right d bushes for my car. When I put in my reg to check the size some of them were 20mm and others were 18. Also is there any point in getting poly D bushes instead of the normal rubber? Are they worth the cost? Thanks again.
Polybushes for ARB retention are a waste of money, it doesn't matter if the ARB moves a bit more as long as it stays put, that's all the bushes are for.
  • Sponsor
See if there's a PR code on the build sticker that tells you the size. I'll post a link to a suitable etka page for the options in a minute.
  • Sponsor
0AQ, 0AR, or 0AS.
See part numbers etc here (view on a non-phone screen to be sure of seeing all the info columns.)  suspension; shock absorber (spring cyl.) - Fabia(FAB) [EUROPA 2012 year] (7zap.com)
I seem to remember that the actual bar diameter is a couple of mm bigger than the numbers shown corresponding to the three PR codes 0Ax. There's some squish of the rubber when fitting.
View on a non-phone screen to be sure of seeing all the info columns.
measure it ?????:notme:
Thought i'd get away with only having the wheels off the car once lol.
full steering lock with wheels on you should be able to see the roll bar to measure
