vcds help
can anybody help with telling me how to work vcds got some problems with car which i cant sort out
If you post a copy of the full autoscan and a list of the problems tag you are having then people should be more able you help you.
hi first started with battery draw anyway track it down to the skoda admundsen radio which  i fitted dont no why it was doing it but it was i didnt code it in coz didnt know how to but it worked then tracked the battery drain down so took it out and fitted origanal one back in now more codes haves cropped up and the park sensor on the back which work through radio are not doing now it doesnt have sat nav now either think the radio is the dance model i live in oldham manchester if any one is near by many thanks for your time
Monday,25,January,2021,09:47:52:62939
VCDS Version: Release 11.11.6 (x64)
Data version: 20121223
Chassis Type: 5J - Skoda Fabia II
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBDG65J2A3143050   Mileage: 245670km/152652miles
Address 01: Engine        Labels: 038-906-019-AXR.lbl
   Part No: 038 906 019 NS
   Component: 1,9l R4 EDC G000SG  0984
   Coding: 00102
   Shop #: WSC 13765
   VCID: 75E1075F4F34EDB003D
   TMBDG65J2A3143050     SKZ7Z0I5672697
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS.lbl
   Part No SW: 6R0 907 379 J    HW: 6R0 907 379 J
   Component: ABS 8.0 front   H06 0003
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002193
   Shop #: WSC 13765 790 00000
   VCID: 4581B79F0F543D3053D
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 5J0 907 044 A
   Component: CLIMAtronic SK25    0608
   Shop #: WSC 00000 000 00000
   VCID: 285F1E2B9806C05848B
Address 09: Cent. Elect.        Labels: 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E73D8733A826EE8127
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
            49-00 - No Communications
01304 - Radio
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 F
   Component: QA AIRBAG VW61 Q5Q6 0004
   Coding: 20801
   Shop #: WSC 13765
   VCID: 275D1D17C518CF20411
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 941 C
   Component: KOMBIINSTR.    V2802506
   Coding: 18404
   Shop #: WSC 13765
   VCID: 2B55E127D9F0EB40A59
1 Fault Found:
00464 - Control Module with Display for Radio and Navigation (J503)
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000J GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0EFB64BB056489850B
2 Faults Found:
01304 - Radio
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2802506
   Coding: 18404
   Shop #: WSC 13765
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10110
   Shop #: WSC 13765
   VCID: 2E53E833EAE29E68827
Address 46: Central Conv.        Labels: 6Q0-959-433.lbl
   Part No: 5J0 959 433 A
   Component: 05 Komfortgerát     0001
   Coding: 00018
   Shop #: WSC 13765
   VCID: 3169F34FFBDC81909F5
Address 56: Radio        Labels: 5M0-035-1xx-56.clb
   Part No SW: 5J0 035 161 A    HW: 5J0 035 161 A
   Component: Radio         007 Radio         007 Radio         007 Radio         007 Radio         007 00140014001400140014
   Coding: 05000400000600
   VCID: 204F060B3036381800B
   Note: Excessive Comm Errors
Address 76: Park Assist        Labels: 5J0-919-283.lbl
   Part No: 5J0 919 283 A
   Component: Einparkhilfe        0001
   Revision: 00012000    Serial number: 09112237230974
   Coding: 0001110
   VCID: 306FF64BA0D6889890B
End   ---------------------------------------------------------------------
The full stop and capital key is on your keyboard for a reason.
Im not 100% sure but as you've identified it's since you've fitted the Amundsen radio, I believe it can be a common issue to result in the battery draining.
Plenty of results come up, just search Amundsen battery drain. I think the solution is to upgrade the CAN gateway, dont know how or what is involved as in does it need to be coded afterwards?
Take a look here:
Hope that helps or at least, point you in right direction.
hi 26DIPP thought i was here for a bit of help with a problem with my car not a grammar lesson but you must be a school teacher and your missing work my mum always said if you cant say anything nice say nothing
hi trickstargee the vcds reading is after when I've re-fitted the original radio back in i can live without the admundsen in it now so still got a problem with the dance radio in it sorry for any confusion
Edited by biggaz
wrong reply
biggar, in my opinion the way that you write your posts does not make it easy for people to understand what you have done. As I read it you took the Dance radio out of your Fabia and installed an Admundson. You then had a battery drain problem which you traced back to the new radio. As trickstargee said this is a known problem when fitting some radios to older cars and it requires a more modern CAN gateway fitting and coding to cure the problem. You then removed the Admundson radio and refitted the Dance.
If you did not do any coding with VCDS whilst the Admundson was fitted then I can think of no reason why the Dance radio would not work when refitted the same as it did before it was removed. I assume that you disconnected the battery every time you removed and fitted a radio to prevent blowing a fuse or shorting out one of the electronic modules? I would suggest that you clear all of the fault codes and then see which ones return.
On the autoscan that you posted the VCDS version is 11.11.6. The current version is 20.12 and I would suggest that you upgrade to the correct version as it includes more functionality. However if you have a pirated version of VCDS, such as can be bought from China, then you will not be able to upgrade it. Pirated versions of VCDS have been known to not work correctly and can cause problems with the coding. It is also Briskoda policy that discussions regarding pirated versions of VCDS are not allowed on the forums.
Some people (myself being one) have difficulty processing written text and understanding what the person writing it was trying to say, it's just the way their brain is wired. When you write a big long run-on sentence with no grammar or punctuation, you're making it much, much harder for people to read it and understand what you're trying to say. My immediate reaction to what you posted above was to switch off and walk away because of the effort needed to try and figure out what you said.
You've been given good advice on this thread by other posters. Start with that and report back with what you find.
Hi liger1956 I didn't disconnect the battery whilst swapping radios over just had the ignition turn off and I bought vcds off independent vw dealer in the north east. And I have cleared all the codes after fitting the dance and what you see is what has returned
Even when the ignition is turned off there is usually a permanent live to the radio so that it can retain it's settings. It is always good practice to disconnect the battery when working on electrical, particularly electronic, components.
Can you update your copy of VCDS to the latest version, which is downloadable for free from the Ros-Tech site https://www.ross-tech.com/vcds/download/ and do another auto scan as the latest version of the software may give us more information.
Are you sure that you did not change anything with VCDS when you fitted the Admundson as one of the faults in 09: Cent. Electronics is
"01300 - Control Module for Navigation with CD-Rom (J401) 49-00 - No Communications"
which would appear to indicate that someone has changed the radio module to include a sat-nav and the Dance does not have sat-nav.
I agree, it seems it's looking for something thats not there and "should" never have been till now..............................
unless offcourse the previous owner had one in, had it coded but never changed it back when they removed the nav unit to sell seperately most likely.
Just in the middle of updating VCDS. I have not change anything as I don't know how to, All ive done with it is read and clear codes
Not sure of its history,so cant say
I have updated vcds now we plug it in tomorrow first thing and post findings, do you cycle the key on and off when clearing codes or not necessary
Yes, after you've cleared them.
I do not think that would be the case as biggaz said that the Dance was working as were the rear parking sensors prior to fitting the Admundson although I could be wrong. What confuses me is that the Dance was working correctly before the Admundson was fitted but not when it was reinstalled even though no coding was altered.
Hi all updated vcds and now I cant get it to see the interface followed the video on ross tech web page. Any advise would be appreciated
Forgot to mention reinstalled back to oringal and it see it, HEX+CAN version 12.12
That would indicate to me that you do not have a genuine version of VCDS and that the software supplied with it is a pirated version. How much did you pay for it?
Bought it about 5-6 years ago, and I think it was somewhere between 150-200 pounds if memory is correct and I did buy it from and vw dealer plus it has a product serial number
In which case, reinstall the latest 20.12 version and contact ross-tech for support (https://forums.ross-tech.com/index.php).
Assuming it's a genuine interface, I'm sure they'll help you to get it up and running :)
Feel free to post a picture of it as that may also help clear this up.
I have already emailed ross tech this morning
Hi Biggaz... I see you mentioned reverting back to the Dance stereo, did you recode that ok? Does it actually work now? Did you actually try to disconnect the battery for a while, then re-connect and turn everything back on again? It does clearly seem you have messed the codes up or something by swapping the audio but I hope its a glitch, not a b1tch, to sort. Have you tried to remove the Dance again, to be sure to connect everything properly, too? You might have missed something.
Hi I've not disconnected battery at all, I've not coded radio in coz i don't know how to, Radio all working except when put in reverse it used to come up on radio now it doesn't. Just done another scan and its say left park sensor faulty would that stop it working though radio. Here's the last scan i did
   Coding: 00102
   Shop #: WSC 13765
   VCID: 75E1075F4F34EDB6B75-4A9C
Readiness: 0 0 1 1 1
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.lbl
   Coding: 0002193
   VCID: 4581B79F0F543D36E75-5000
   VCID: 285F1E2B9806C05EFC3-50E6
   Coding: 25742
   Shop #: WSC 13765
   VCID: 3E73D8733A826EEEA6F-5000
2 Faults Found:
01304 - Radio
   Coding: 20801
   Shop #: WSC 13765
   VCID: 275D1D17C518CF26F59-5000
   Coding: 18404
   Shop #: WSC 13765
   VCID: 2B55E127D9F0EB46111-5072
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Coding: 00014
   Shop #: WSC 13765
   VCID: F0EFB64BB056489EE43-5000
2 Faults Found:
01304 - Radio
   Coding: 18404
   Shop #: WSC 13765
   VCID: 2B55E127D9F0EB46111-50E6
   Coding: 10110
   Shop #: WSC 13765
   VCID: 2E53E833EAE29E6E36F-5000
   Coding: 00018
   Shop #: WSC 13765
   VCID: 3169F34FFBDC81962BD-4A3A
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Component: Radio         007 0014
   Revision: R0007000    Serial number: SKZAZ4I0077824
   VCID: 204F060B3036381EB43-5000
   Coding: 0001110
   VCID: 306FF64BA0D6889E243-50E6
1 Fault Found:
01545 - Sensor for Parking Aid; Rear Left (G203)
            003 - Mechanical Failure - Intermittent
