US Blinkers activation
I can't find in any vcds adaptation topics on how to activate US Blinkers through vcds on Oct III. Where can they be dimmed, if acticated?
I would want front blinkers to work as drl with fog lights. Is it even possible through coding?
Fog lights as DRL is here:
Yes, I have that, but cant find US style blinkers as drl as well.
It’s in this post.
Thanks.
@SC03OTT I can't find US blinkers as DRL, there is only US blinkers with low beam
I have enabled US blinkers with low beam already, if it helps any bit.
Basically I would want to have US blinkers on with low beam and also work as drl with fog lights. I currently have US blinkers working together with low beam. I also have only fog lights as drl(original h15 drl not working), but I would want to have US blinkers on as well.
