Reading current flow diagrams
Is anyone good at reading current flow diagrams? For a skoda superb, how am I supposed to find the physical location of things that are inside circles on these diagrams, like 'B503 − Positive connection 7 (30a), in interior wiring harness', when B503 is not mentioned in the other wiring documents that I can find inside erwin like 'fitting locations - coupling stations and plug connections of wiring harness, fitting locations for control units, fitting locations - fuses, fitting locations - relays or even 'basic information' diagram
I feel like there's a document in erwin somewhere that shows these locations that I can't seem to find
You can find or tap into B503 directly from fuse 10 as shown above or you can follow the [46] or [29] to see which other connectors it goes via and tap into it there :)
It's not shown in your image but there should be some numbers along the bottom to help. Couple of examples:
- 6 and 7 are linked (same diagram)
- 4 and 72 are linked (different diagrams in the same set)
Those connections in circles tend to be splices within the loom, crimped-together wires taped up and a bit hard to spot when the loom is fully taped.
Here's an example of a (unwrapped) two-into-one earth wire splice that @JoeF posted recently. The relevant wiring diagram would show that as a similar 'number in circle' thing to what you're seeing.
Thanks so much. I actually figured out the bottom-of-page number-linking system, I just naively expected there to be a diagram of locations of the circled places :D I'll just have to follow the wires like you say.. !
