The Definitive VCDS / OBD11 / Carista list for the Fabia III
Updated Adaptations and Coding list for the FABIA NJ 2015 >
***all adaptations are done at your own risk, and Briskoda will not be held responsible for any problems that could occur. Always keep a copy of your auto scan / backup before attempting any coding***
***Carista doesn't have a backup feature so please take care to make changes slowly and one at a time***
CARISTA
This is a cheap OBD2 dongle which allows limited adaptations to your vehicle via their iOS and Android Apps. listed below are the known common adaptions that you can enable via the app - More info on this device and the full list of customisations that it offers for the Fabia NJ can be found here - https://caristaapp.com/vehicles/skoda/fabia/nj
*They mention you can activate opening of windows on long hold of the button on the key. This will not work on this model of Fabia due to the limited wiring / design of the window assembly in the door.
*Some users have mentioned they have been able to activate Hill Hold Assist using Carista, personally this feature wasn't available on 3 different Fabias that I used. From my findings on here its hit and miss if you will get access to this customisations. It's also not listed as one of the customisations on their website
- Needle Staging
- Unlock and Lock Chirp
- Seat Belt Warning ***(This is not advised as wearing seatbelts is for your own safety)
- Chime / ding when key left in ignition
- Refuel quantity in MFD
- Cornering light activation ***(must have fog lights fitted to car)
- Auto Lock doors when moving
- Bolero start up screen change
- Change auto light sensitivity ***(must have light assist installed)
- Hill Hold Assist ***(this isnt mentioned on the Carista website but users have been able to change it, others haven't)
VCDS / OBDEleven
OBDEleven is an iOS and Android OBD2 Dongle that allows more in-depth adaptations and customisation via their pre installed 'apps' or via Long Coding in the relevant modules for the car for your vehicle via your phone.
Instrument cluster / MFD
NEEDLE STAGING
- ECU17 (Instruments)
- Coding
- Byte 1
- Bit 0: enabled (Default: disabled)
LAP TIMER
- Coding
- Byte 1
- Bit 3: enabled (Default: disabled)
REFUEL QUANTITY
- Coding
- Byte 10
- Bit 4: enabled (Default: disabled)
Infotainment
BOLERO SPLASH SCREEN
- ECU5F (Information electronics)
- Coding
- Byte 18
Logo                 Bit 0        Bit 1       Bit 2
Skoda (Default)   disabled   disabled   disabled
RS                     enabled    disabled   disabled
L&K                   enabled    enabled    disabled
Monte Carlo        enabled    enabled    enabled
Scout                 disabled   enabled    disabled
Greenline            disabled   disabled   enabled
Big thanks to @yankarinRG for finding this out :thumbup:
Change 'Auto Light' sensitivity in radio
Module 09
Adaptations 10
Assistance_lighting_sensitivity_adjustable = Present / available (Default 'Not Present' 'not available')
Thanks to @wirer for this :thumbup:
Enable the Service Mode of the wipers in the radio
Module 09
Adaptations 10
(12)-Windshield Wiper-Menuesteuerung Frontwischer = Active (Default 'Not Active')
ABS
HILL HOLD CONTROL
- ECU03 (Brakes)
- Coding
- Byte 22
***Activating this will cause the car to throw a few errors, turn car ignition off, remove key, then re insert the key and turn the ignition back on. You will see the errors are no longer there. If they remain, reverse the coding to deactivate Hill Hold***
Lights
LED DRL DIM WHEN USING INDICATORS
- ECU09 (Central electronics)
- Adaptations
-----Left-----
- "Leuchte2SL VLB22 "
- "Lichtfunktion C 2"
- Set "BlinkenlinksRampe" (Default: "Blinken links aktiv")
-----Right----
- "Leuchte3SL VRB36"
- "Lichtfunktion C 3"
- Set "BlinkenrechtsRampe" (Default: "Blinken rechts aktiv")
 Thanks to @yankarinRG for sharing this :thumbup:
STATIC CORNERING LIGHTS THROUGH FOG LIGHTS
- Adaptations
-----Left-----
- "Leuchte12NL LB40"
- "Lichtfunktion B 12"
- Set "Abbiegelicht links" (Default: "nichts")
-----Right----
- "Leuchte13NL RB3"
- "Lichtfunktion B 13"
- Set "Abbiegelicht rechts" (Default: "nichts")
Coming home/Leaving home for cars without Fog Lights (Using DRL's)
- Adaptations
-----Left-----
- Leuchte 6 ABL LB44
- Light function C6
- Set "Coming Home / Leaving Home active"
- Dimming C6
- Set "0"
- Dimming direction CD6
- Set "minimize"
-----Right-----
- Leuchte 7 ABL RB5
- Light function C7
- Dimming C7
- Set "0"
- Dimming direction CD7
- Set "minimize"
***If you have problems with low beams (flashing on and off), then you should do the tweaks in "Leuchte 12NL LB40" and "Leuchte 13NL RB3" instead of "Leuchte 6 ABL LB44" and "Leuchte 7 ABL RB5"***
Alternative coming home/leaving home for cars without light sensor
I'm not sure, if the lightfunction is named Umfeldbeleuchtung or Umfeldlicht
Controller 09
security access: 31347
Adaption
Leuchte2SL
         Lichtfunktion G2 =  Umfeldbeleuchtung
         Dimmwert GH2 = 10
Leuchte3SL
         Lichtfunktion G3 =  umfeldbeleuchtung
         Dimmwert GH3 = 10
Leuchte4TFL
         Lichtfunktion E4 = Umfeldbeleuchtung
         Dimmwert EF4 = 127
Leuchte5TFL
         Lichtfunktion E5 = Umfeldbeleuchtung
         Dimmwert EF5 = 127
Leuchte20BR
         Lichtfunktion E20 = Umfeldbeleuchtung
         Dimmwert EF20 = 18
Leuchte21BR
         Lichtfunktion E21 = Umfeldbeleuchtung
         Dimmwert EF21 = 18
Leuchte23SL
         Lichtfunktion C23 = Umfeldbeleuchtung
         Dimmwert CD23 = 100
Leuchte24SL
         Lichtfunktion C24 = Umfeldbeleuchtung
         Dimmwert CD24 = 100
Leuchte25KZL
         Lichtfunktion B25 = Umfeldbeleuchtung
Thanks to @djduese for this :thumbup:
Dimming of number plate lights when opening boot
Controller 09
Security access: 31347
Adaptation 10
Leuchte25KZL HA60
 Light_Function_E_25 = 'Heckdeckel Offen' (Default 'Nicht Aktiv')
Dimming_Direction_EF_25 = minimise (Default 'maximise')
Dimming_EF_25 = 10% (Defualt '0%')
***you can choose any value from 0%-100%, this will define the brightness of the bulb once boot is opened***
Turn on mirror amber light with interior light
Controller 09
Adaptation 10
Leuchte16BLK SLC11
Light_Function_G_16 = Innenlicht (Default 'Nicht Aktiv')
Dimming_GH_16 = 100% (Default '0%')
Leuchte17BLK SR A72
Light_Function_G_17 = Innenlicht (Default 'Nicht Aktiv')
Dimming_GH_17 = 100% (Default '0%')
Emergency Break/Flashing Lights
Select Control unit 09 (Central Electrics)
Control unit Long Coding
Byte 16
Bit 1 Activate
Bit 2 Activate
Activation of Coming Home/Leaving Home
Byte 10
Bit 1-Bit 2 Activate
Activating Fog Lights after Retrofit
/Leuchte12NL LB40
Type of Load 12 (lasttype)
 Nicht Aktiv --> Allgemein Scheinwerfer
Light function A12 (Lichtfunktion A12)
Nitch Aktiv --> Nebellicht Links
Dimming AB 12 (Change value)
0 --> 100
Leuchte13NL RB3
Type of Load 13 (lasttype)
Nitch Aktiv --> Allgemein Scheinwerfer
Light function A12 (Lichtfunktion A13)
Nitch Aktiv --> Nebellicht Rechts
Dimming AB 13 (Change value)
0 --> 100
Thanks to @JGrindel and @langers2k for this :thumbup:
Lighthouse call with fog lights (in addition with high beam)
Control unit 09 (central electrics)
Adaptation
Leuchte12NL LB40 ---> Light_Function_B_12 ---> Lichthupe
Leuchte13NL RB3 ---> Light_Function_B_13 ---> Lichthupe
Thanks to parigot47 from the OBDEleven Forum for this
Wipers
Activation of Tear Wipe on front windscreen
Method 1 (Didn't work for me personally)
Byte 14
Bit 4 Activate
Method 2 (VCDS)
Controller 09
Adaptation 10
(15)-Windshield wiper-Traenenwischen Front Status = Active (Default 'Not Active')
Method 2 (OBDEleven)
09 Central Electrics
Adaptations
Controller 09
Adaptation 10
(4)-Rear Window Wiper-Traenenwischen Heck = Active (Default 'Not Active')
Disabling Rear Wipe in Rear Drive
Byte 14
Bit 3 DeActivate
OPS / Parking Sensors
Parking Sensor Trajectory
Module 10 - Park/Steer. Assist
- Coding 07 - Long coding
Byte 1 - Bit 4 Limited Operation active / enabled check (from 0 to 1)
Byte 1 - Bit 5 Vehicle Path Display active / enabled check (from 0 to 1)
Central Locking
Unlocking Door when Stop the Car
Byte 0
Bit 3 Activate
Locking Door up to 15 km/h
Byte 0
Bit 4 Activate
Locking Door After 30 sec
Byte 4
Bit 5 DeActivate
Lock Acknowlegde with Horn
Byte 5
Bit 1-Bit 4-Bit 7 Activate
Lock and Unlock beep / chirp
Select Control Unit 09 (Central Electrics)
Adaptations
Acknowledgement Signals
Akustische Rueckmeldung entriegen = Active (Default 'Not Active')
Akustische Rueckmeldung verriegeln = Active (Default 'Not Active')
Menuesteurung akustische Rueckmeldung = Active (Default 'Not Active')
(this activates a check box within the cars settings allowing you to turn the beep/chirp on and off without coding)
Akustische Ruechmeldung global = Active (Default 'Not Active')
Start / Stop
Disabling start-stop system
***Please carry out any modifications and coding AT YOUR OWN RISK!!!. I will not be held responsible for any damage of the vehicle and I am just giving you the steps***
1. Enter 19-CAN Gateway
2. Click on Coding-07
3. Click on Long Coding Helper
4. Change Byte 3, Bit 2-3 (Drop down menu) from 04 Start/Stop System with Recuperation installed [PR-7L6]  to 08 Start/Stop System NOT installed [PR-7L3]
5.Change Byte 4, Bit 0 to 0
6.Change Byte 15, Bit 0 to 0
7. Click on Exit - top left hand corner
8. Click on Do it!
Voila you are done!
Thanks to @kickdown for this
:handshake:THANK YOU TO ALL THOSE WHO FOUND THESE CODING ADAPTATIONS OUT OVER THE YEARS :handshake:
@wirer
 @djduese
 @yankarinRG
@langers2k
@kickdown
Links to devices mentioned within this thread
Carista OBD2 - https://amzn.to/3mHTX2Z
OBDEleven - https://amzn.to/32aylmA
VCDS - https://store.ross-tech.com/shop/cat/vcds/
***JGrindel is a participant in the Amazon Services LLC Associates Program, I get commissions for purchases made through the Amazon links in this post***
Edited by JGrindel
  • Like 2
  • Love it! 1
  • JGrindel locked and unlocked this topic
Sources
https://obdeleven.proboards.com/thread/175/coding-adaptations
@wirer - https://wirer.sk/
He has some awesome guides on all things retrofits for the NJ Fabia. Well worth a look
Unlock and lock beep
https://www.vwroc.com/forums/topic/14420-vcds-alarm-chirp-on-lockunlock/
Edited by JGrindel
  • Thanks 1
  • JGrindel locked, unlocked, locked, unlocked, locked, unlocked and locked this topic
  • john999boy pinned this topic
  • JGrindel unlocked and locked this topic
  • JGrindel unlocked, locked and unlocked this topic
  • JGrindel locked this topic
  • JGrindel unlocked, locked, unlocked and locked this topic
Guest
