OBDeleven ?
Anybody know when obd11 will work / be compatible with the mk4 octavia?
It could be a long wait - VAG have implemented something called SFD which means that some coding & adaptation changes can only be made once a token has been sent from the VAG servers - which third party diagnostic tools like VCDS/OBD11 etc. cannot be.
See this for an explanation.
BTW they have also implemented on some vehicles a requirement to open the bonnet/hood to be able to make some coding/adaptation changes.
Doesn't suprise me. I was adding things to my mk3 that would've costed hundreds to add at a dealership
  • 6 months later...
This is finally possible, just need to find a list of unlocks available before i decide if it's worth buying
if you have coding list share it :)
I manage to add power, torque, vrs cluster graphic design, lock the car while running when outside...
Didnt manage to make needle sweep, gmeter, third rear light for ch/lh...
hello please add manual how to change cluster to vrs, and add lock car after engine runnig, :)
Is it possible to lock cars when you leave it?
Since its possible to open doors on approach.
Hello,
Its possible to lock the car from outside while the engine is on.
The car will unlock automatically when the key is nearby
Hi brankokotor,
Could you provide further details, a tutorial or a link with the steps to follow in order to activate the options that you mentioned? (power, torque, VRS cluster, lock car with running engine)
Thanks!
Hi, I will post afternoon. Regarding power, torque, car lock - simple, only change off to on, but vrs cluster need to change more parameters
Plug the device into obd socket, open app on the phone.
Need to pass verification in order to be able to unlock anything. Its explained on obd eleven blog how to do it..
Description how to do it is here
VRS CLUSTER THEME
17 - Adaptations - view activation - all which are OFF should be ON
The rest I did from car app menu, just turn from off to on.
I manage to put wheel steering angle, but from some reason it is opposite
Strangely I WAS able to add g-meter but not power and torque displays.
Seems a bit hit and miss
Will the OBDeleven read codes in the MK4? I have a recurring passenger airbag warning which comes and goes. Would like more info when it comes on so that I can speak to the dealer?Thank you.
No issues reading codes here.
10 hours ago, wainfleetworld said:
hello @wainfleetworld
obd can read code just connect car select airbag and obd show code:) for your talking you have problem with seatbelt
Thank you for your confirmation of what OBDELEVEN can do.
I received my device yesterday and within 10 minutes my airbag light was reset!!!!
When I jumped off the fuse box I removed the airbag switch and cable. I turned the ignition ON when the switch and cable were disconnected. Appears that the car didn’t like this and that is what the fault was for.
All now sorted. Lots more to investigate within tbe OBDELEVEN app.
Can you enable normal cruise for octavia 4? I know its possible with Enyaq.
i dont tested you have  coding ?
Nope, since i dont know if its possible or not :)
