Possible VCDS tweaks in skoda fabia mkii 5j?
Recently I bough a VAG-COM-HEX-V2 interface and was getting to know the VCDS. Though I bough the VAG-COM mainly for diagnosing any issues, I was curious if I can use it enable the stuffs like remote key window rolling up down and needle sweep.
Only problem is (at least what I think) is mine is a pretty old model(2010) which doest support long coding as VCDS doesn't show long coding helper as most of the forum post instructs us to work with long coding I wonder if this is possible at all.
Things which I am planning to do are:
1- Convenience remote control window up and down.
2 - Needle sweep / Celebration when we turn on the ignition.
Any other mods which will be fun is really appreciated:
Posting my VCDS scan details which contains all the module versions which can be useful if someone tries to help me. Thanks in advance.
Chassis Type: 5J (5J - Skoda Fabia (2007 > 2010))
Scan: 01 02 03 08 09 15 16 17 19 25 37 44 46 55 56 76 77
VIN: TMBBHH5XXXXXXXXXX   Mileage: 72610km-45117miles
Address 01: Engine        Labels: 03E-906-033-AZQ.lbl
   Part No: 03E 906 023 N
   Component: SIMOS91 1.2l 4V     3515
   Revision: --H04---    Serial number: SKZ7Z0I5402287
   Coding: 0000071
   Shop #: WSC 01234 785 00200
   VCID: 2A5BB7AF86FFC0D47D-515A
1 Fault Found:
16955 - Brake Switch (F)
            P0571 - 008 - Implausible Signal - Intermittent
Readiness: 0010 0001
Address 03: ABS Brakes        Labels: 6R0-907-37x-ABS80.clb
   Part No SW: 6R0 907 379 J    HW: 6R0 907 379 J
   Component: ABS 8.0 front   H06 0003
   Revision: 00000000    Serial number: 00000000000000
   Coding: 0002100
   VCID: 4581E4130FA10FAC70-515A
3 Faults Found:
00526 - Brake Light Switch (F)
            011 - Open Circuit
01314 - Engine Control Module
            004 - No Signal/Communication - Intermittent
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -  - Intermittent
Address 08: Auto HVAC        Labels: None
   Part No: 5JF 820 045 C
   Component: Klimaanlage         00.9
   VCID: 3B7582EB2965495C16-513C
No fault code found.
Address 09: Cent. Elect.        Labels:. 6Qx-937-049-C.lbl
   Part No: 6Q1 937 049 F
   Component: 0000 BN-SG.         2S36
   Coding: 25742
   Shop #: WSC 01234
   VCID: 3E738BFF3A775C7431-515A
2 Faults Found:
            49-10 - No Communications - Intermittent
01304 - Radio
            49-00 - No Communications
Address 15: Airbags        Labels: 6Q0-909-605-VW5.lbl
   Part No: 1C0 909 605 K
   Component: S1 AIRBAG VW51      0011
   Coding: 21297
   Shop #: WSC 01234
   VCID: 2C57B1B7DC0BDEE48F-515A
Address 17: Instruments        Labels: 5J0-920-xxx-17.clb
   Part No: 5J0 920 801 B
   Component: KOMBIINSTR.    V2802476
   Coding: 16103
   Shop #: WSC 10039
   VCID: 25414493BFE1EFAC50-515A
1 Fault Found:
Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
   Part No: 6N0 909 901
   Component: 000J GATEWAY CAN    2S36
   Coding: 00014
   Shop #: WSC 01234
   VCID: 70EF65C730A3FA04F3-513C
2 Faults Found:
01304 - Radio
Address 25: Immobilizer        Labels: 5J0-920-xxx-25.clb
   Component: IMMOBILIZER    V2802476
   Coding: 16103
   Shop #: WSC 10039
   TMBBHH5XXXXXXXXXX     SKZ7Z0I5402287
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156
   Component: LenkhilfeTRW        V272
   Coding: 10140
   Shop #: WSC 01234
   VCID: 6DD17CB3279117ECD8-515A
1 Fault Found:
Address 46: Central Conv.        Labels:. 6Q0-959-433.clb
   Part No: 5J0 959 433 A
   Component: 06 Komfortgerát     0001
   Coding: 00019
   Shop #: WSC 01234
   VCID: 3169A0C3FB29B30CBC-4B18
End-------------------------(Elapsed Time: 03:41)--------------------------
I forget the name for it but you can set it to unlock all doors on the first press.
Ours is 2009, i.e. pre face lift. You do not have that many coding options. Some are the old fashioned version of calculating and adding specific values.
I do not think I coded needle sweep.
The locking is called Auto lock. I think you can set that in the Maxidot....
Selective Unlocking
I use a dustpan and brush to sweep the needles that fall off the tree at Christmas, I have no idea why you'd want to try and program a ten year old car to do it for you.
You must have a lot of time on your hands.
You can get the stereo display to show MPH, if you fancy it! I only found out some while ago and would have had it done from the dealer if I had known!
Are you saying you get a large MPH readout in the Maxidot? What is the coding and what year is yours?
yes you can get a large MPH on the maxidot.
You have to set the vehicle to "rest of world" spec with VCDS or similar and turn off ALT speed disp in maxidot settings.
You then have the option for a digi speedo
Edited by UrbanPanzer
I was referring to the stereo or at least, the dance unit. Apparently, the display can have MPH enabled, for driving instructors, etc.
Unfortunately I dont have maxidot in console, Mine is older and have predesigned lcd in the center console.
Update :
I guess the 5J platform Fabia have old control units and doesn't even have long coding support  and VCDS doesn't have much info on the bytes and their info.
I was able to do some of the below things.
1- Increase the steering assist from normal to higher level in low speeds
2- Increase the number of convenient turn indicator blinks to 3 blinks to 5.
Autolock?
One touch lock?
Wiper tear?
  • 7 months later...
Can you please share the coding for the above ?
Wish I'd know this, that would be sweet!
You actually want to swap a 3 flash chop for a granny signal!?
I dont get what you mean..but eventually yes...
