Felicia 1.3 mpi oil leak
Hi, I've just bought a Felicia pacific estate 1 3 mpi, which is a lovely low mileage car.
One of the few problems I have is an oil leak from the cam follower cover on the side of the engine. I'm after the parts numbers for the gasket and the rubber washers that hold the plate in place if anyone can oblige.
Thanks in advance.
There is a pinned topic in this section of the forum called Online catalog with PART NUMBERS and ILLUSTRATIONS
Before presuming I needed a new cover gasket I'd check the torque on the cover bolts is right. I've fixed several similar sounding leaks that way for no money and next to no time.
Edited by KenONeill
047103483 valve cover gasket
047103532 rubber round things below nuts
  • 5 years later...
Very late replying, but I had a failure in my Swedish MOT yesterday because of an engine oil leak. Spent most of today degreasing and washing the engine bay of my 1999 1.3 Felicia and discovered the leak was from the cam follower cover. When I checked the cover bolts, 2 were finger tight and the other 2 were not much better.....
To be on the safe side I've ordered a new gasket and 4 of the cover bolt rubber seals.....
Just a follow up - the part number (OEM) for the cam follower cover gasket is actually 047103727, not 047103483 as quoted earlier. I only found out when I ordered without double checking and got a rocker box cover gasket instead.
The rubber seal part number is correct, but only because the seals are the same for the cam follower cover and the rocker box cover.....
You mean this one?
2407.PL - Car Parts Store
No image preview
047103727 VAG - Gasket 047 103 727 - price on 2407.PL
Gasket VAG 047 103 727 - 21 PLN in online store 2407.pl ✅ Good price ✅ Fast shipping ✅ Hotline 8:00-18:00
It's very cheap, usually is changed after few oil changes and some mechanics (meanwhile) put gasket seal.
Thanks, yes, that looks like the one. I reused the old one with gasket seal as a temporary measure and made sure the nuts were tightened this time - fixed the leak enough to pass the Swedish registration check....
