Track rod end spinning.
Typical they only have 1 left :(
  • Replies 64
  • Views 5.8k
  • Stewartasb
    Stewartasb
    Yes looking like cutting it unfortunately  I don't own a grinder so looking like hacksaw and a fresh pack of blades and arm ache 🙄
  • sepulchrave
    sepulchrave
    A Dremel will split the nut easily enough if you don't have a grinder.
  • Stewartasb
    Stewartasb
    Good point I did not think about my dremel cheers sepulchrave 👍
Try your local GSF. :)
found some thanks guys as always for sorting me out yet again going to go sit in the corner for a while and have a tantrum :P
Quote
OK, well the part number is Kilen 23106. Think there is plenty more on ebay.
EDIT: Never mind, you found some :thumbup:
Edited by TMB
Just one last quick question as always lol does anyone know the torque setting for the main brake caliper bolts as im going to take this opportunity to change my pads and discs while i,m re stripping the rest ???
Slider pins are 28Nm for FSII & FSIII calipers. Pins are 7mm Allen for FSIII which are on the 1.4 MPI. Disc size is 256mm.
There are no other caliper mounting bolts as the pins go straight into the hub casting....
Edited by TMB
Cheers tmb do these measurements look correct ???
Key Points
Quantity Included: 2 Discs & 4 Pads (Axle Set)
Brake Disc Type: Vented
Number of Holes: 5
Disc Diameter (mm): 255.8
Brake Disc Thickness (mm): 22
Disc Height (mm): 36.7
Pad Length (mm): 146
Pad Thickness (mm): 19.5
Pad Width (mm): 54.8
Extra Info: With Integrated Wear Sensor
No wear sensor on Fabias, otherwise good.
Thanks sepulchrave i had not noticed that at the end will get the set without :)
My pads came with wear sensors. I just cut the 2 wires off.
Cheers guys okay got 2 more questions lol firstly does anyone know the correct part number for the front flexi brake hoses as ive noticed while doing my work both have a split in them not leaking but into the core so I will want to change those and secondly my mate phoned me up about this drivers side drive shaft nut ok so he has the 19mm hex socket but has to take his wheel off to get at it as he has alloys on now the trouble is every time he puts pressure on it to loosen the nut the drive shaft turns so he cant crack it to loosen it off any ideas please ???
6R0611701H for the flexi hoses.
Has he not got a steel spare he could fit that would give access to the hub nut for loosening?
Edited by Wino
thats a point i could lend him my spare mine is just a steelie will that be okay then just fit it on then crack the nut whilst on all fours yes ???
Last question I promise might as well do a brake fluid change while im at it do you know how much I need to totally bleed the system have a new 1 litre bottle is that enough ???
More than enough.
