Car issues - help kindly requested :) ABS - Auto HVAC - Central electrical system - Wipers - Canbus - Door electrical system - Steering assist
Hi, I ran a vcds and got up a few issues. I have searched the internet and tried a lot of diagnostics but probably overlooked some, or done them wrong. So I am asking here directly, if there are already good topics on them please link to them :)
I am a newbie and hope you understand the fault codes better than me, also tried to look them up on ross tech, but can't quite manage to wrap my head around what some of them mean. I have checked the fuses like a thousand times, both under the hood and the one in the car. Searched milennias for relay diagrams, but no luck. Sent a mail to skoda asking for one, will see where that goes. This is a car I will recycle or sell as parts when i am done with it, fixing it is a hobby :)
Skoda octavia 2005 mk2 combi 1.9 tdi.
- Battery changed this spring (2021).
- Bought new horn.
- bought new ABS sensor, ring too if necessary.
- Swapped the engine summer 2020 (blown head gasket). (old one: 308 000 km, new one: 133 000 km, car now: 319 000km)
All help is appreciated :) Ufc 205 Thank You GIF by UFC
<hr style="margin-left:0; height: 2px; border-style: none; background: black;">
[CODE]
 Abs sensor
I have already bought a new sensor, just haven't replaced it yet. Most likely that will fix it, no?
- Should I put in a new ring aswell, or is it more work for no necessary reason?
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60    0102
   Revision: 00T12001
   Coding: 0021121
   Shop #: WSC 73430 790 00000
   VCID: 408F2A661342E942E0-8014
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            003 - Mechanical Failure - Intermittent
<hr>
Auto HVAC
there is no AC refrigerant in the system. Expensive to fill up, is it possible to do it yourself?
- is that what is causing both issues?
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 J
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3D71539264B084AA8B-8068
2 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
            000 -  -  - Intermittent
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
<hr>
central electrical system
- Is terminal 30 what goes directly to the battery?
- What relay goes to the horn? there is no clicking sound when i press the horn with ignition on :(
- I have connected reverse camera to reverse lights. New joying radio connected to lights as well as an amplifier. (so it turns on with the car) better suggestions?
- Fuse for interior light is good, and they work, so don't know why it's complaining?
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000003149599
   Coding: 498A8F030004140000110D000000000000087F075C
   VCID: 3A7B588E759EB392AE-806E
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS     020610 054  0403
   Coding: 00209069
   Shop #: WSC 73430
4 Faults Found:
00926 - Terminal 30
            011 - Open Circuit - Intermittent
00446 - Function Limitation due to Under-Voltage
            002 - Lower Limit Exceeded - Intermittent
00059 - Terminal 30 for Interior Lighting
            012 - Electrical Fault in Circuit - Intermittent
01759 - Relay for Horn
<hr>
steering wheel - wiper switch
- I think this one is the interval switch on top of the stick. don't notice any problems.
   - Any point in fixing?
- My back wiper doesn't work, i think the motor needs to be replaced. Any suggestions as to how to shock it to see if it starts spinning?
    - Functions sometimes, very rare.
    - No sounds, when turning the back wiper on. clicking sound behind wheel tho.
    - 4 pins so not sure how to shock it, suggestions?
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E38CBE010617F28A-8022
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
<hr>
CAN gateway
- Not sure what this means. Radio is swapped so makes sense that it can't find it.
    - Is that a problem?
- What does the first fault mean?
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001054178A56
   Coding: 3D3F4B40072302
   VCID: 295997C28038080AD7-807C
2 Faults Found:
01305 - Databus for Infotainment
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 30
                    Mileage: 314793 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:36:25
01304 - Radio
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 30
                    Mileage: 314793 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 19:36:29
<hr>
Door electrical system - driver side
- Swapped the old broken driver side side view mirror, maybe a different bulb code messing up?
- Couldn't see any obvious breaks behind the door cover.
- Suggestions?
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2345
   Coding: 0000246
   VCID: 36634CBE418657F24A-8062
1 Fault Found:
00131 - Outside Door Handle Illumination/mirror Light Driver Side
<hr>
Steering assist
- Dash light comes on when i take off the battery and stays for a month-ish. what is causing this?
- Steering wheel becomes loose, doesn't return to original position on its own. any fixes?
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 326B70AEADEE4BD266-8066
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 -  -
[/CODE]
The entire scan is added as an attachment in case you want to take a look. the only fault I didn't add was the auxiliary heater where the heater element is defective. took the cable off when i swapped the engine 'cause I don't need it, so don't plan on replacing it, unless you guys want me to ofc!
Log-TMBGS61ZX62123388-318840km-198117mi.txt
Edited by TorH
