Kumho tyre choices
After a long forum search i`m goin to fit sum kumho`s 225/45 but which 1`s. i`ve had a look mytyres and there 5 different ones?
Quite like the look of the ku15 but its the price.
Which ones do you guys run and any probs?
Cheers in advance
GUY
Ku 31`s mate......i`ve got 712`s and they dont instill confidence..
Phil
I've got Ectsa 715. Not a bad tyre for general purpose, wet grip isn't great but i've never ran out of grip in the dry.
I have KU31's They took a few hundred miles to bed in but now they've done so they really are very good.
Not had any problems with wet or dry grip, and on a hot road last week they were VERY nice.
Flat ones
I'm running KU31s. Not that great in the wet and not as good a P Zero Neros in the dry but loads cheaper.
Did they 'bed-in' or did you get used to them??
My Toyos are very good.
Thanks Guys:thumbup: ,
I`ve got the kumbo`s fitted at the weekend at a good price had a bit of problem with one off the valves thou, had to have a rubber one fitted as the local stealer didnt have any in stock . The only prop now is i`ve got quite a lot of road noise.
1. Is it coz i didnt get the front tyres rebalanced as they came off the back.
2. Wrong tyre pressure
3. Tyres not bed in yet
4. Wot do u think
I know the above are easy to find out but my wife works at night and i leave early in the mornin, so i only have weekends to sort things out.
So all your thoughts are appreciated
Which Kumho did you go for ?
Increased road noise is most likely to be the tread pattern.
I went for the ku31`s in the end not a bad lookin tyre, still got the 205`s avons on the front thou at the moment.
