Horn / Steering wheel buttons
Hi all,
New owner of a 2014 Octavia.
Bought it from an auction - Cat N write off.
No real info on it, no service history etc etc.
Runs / Drives perfect,
Only issues being horn / steering wheel  buttons dont work, neither does the Cruise Control.
I assume they'll need some sort of coding?
Any help would be appreciated.
Henry
Horn not working is an MOT failure and means it is unroadworthy.
Sounds like the airbag has deployed, they may have replaced the AB unit, but not connected the steering wheel wiring back up, or it was damaged.
I've had the airbag off, all looks good.
The damage for the write off was to the rear quarter, so no reason to believe the airbag has deployed
A good starting point would be to get it scanned with VCDS or similar for fault codes :)
Ok! I'll have a google and see if anyones local.
Thankyou
Hey guys, just a quick bump.
Cars been sat for a while, finally got around to asking a friend to come and scan the car. I wasn't in, but he sent me the scan results.
Thursday,07,October,2021,16:23:31:00009
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: TMBBJ7NE0E0032991   License Plate: HEN1
Mileage: 68705km-42691mi   Repair Order:
Chassis Type: NE-SK37 (3Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 5F
VIN: TMBBJ7NE0E0032991   Mileage: 68705km-42691miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CKFC)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   X22 5520
   Revision: 83X22---
   Coding: 111D0012030501090000
   Shop #: WSC 92521 052 12345
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_002.rod
   VCID: 7AFB47EFFDDF50565D-802E
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 040 K    HW: 02E 927 770 AN
   Component: DQ250-6F MQB  H52 4028
   Revision: 05652104    Serial number: TFK01305290695
   Coding: 0014
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021.rod
   VCID: 1F4D567B06BDD57E0A-804A
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 61333000000423
   Coding: 1A078A912423096E0080060941C4245851249000608224F000610070C002
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4B95D22BE2C519DEB6-801E
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044     HW: 5E0 907 044
   Component: Climatronic   H02 0604
   Revision: 00001K06
   Coding: 01110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 002017
   ROD: EV_ACClimaBHBVW37X_002_VW37.rod
   VCID: 62CB1F8F754FB89665-8036
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 S    HW: 5Q0 937 084 S
   Component: BCM MQBAB M   H14 0112
   Serial number: 00011318501185
   Coding: 0F001842424700DB07A04082B10407280000000000000000000000000000
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_BCMCONTI 011001
   ROD: EV_BCMBOSCH_011.rod
   VCID: 489FED27F3B3F2C69B-801C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 130612  041 0570
   Serial number:         130614141052
   Coding: 065DDD
   Sensor For Anti Theft Alarm System:
   Subsystem 2 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0313
   Serial number: 000000000ZY13120445D
   Alarm horn:
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000057249563
   Relative Air Humidity Interior Sender:
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20418839
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 B    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H09 0033
   Revision: --------    Serial number: 60831317202854
   Coding: 0001050011
   ASAM Dataset: EV_EPHVA14AU3700000 002018
   ROD: EV_EPHVA14AU3700000_002_VW37.rod
   VCID: 387F9DE783538246EB-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   011 0188
   Revision: --------    Serial number: 003P4PNAPV4L
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0DB6FBE6FD757E6A-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 002 206 13
   Component: SideSensor_Df  008 0887
   Serial number: 3576U000000DBA992D0W
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 206 13
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U000000F1A692D0M
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 506 13
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R93837B01000000+
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 506 13
   Component: SideSensor_Pr  111 0148
   Serial number: 3526RAAE67C01000000H
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 005 13
   Component: FrontSensor_D  114 0149
   Serial number: 3556V16545D01000000%
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 AF    HW: 5Q0 953 549 A
   Component: Lenks. Modul  007 0070
   Revision: --------    Serial number: 11061304400673
   Coding: 9600
   Shop #: WSC 09550 758 180955
   ASAM Dataset: EV_SMLSKLOMQB 009001
   ROD: EV_SMLSKLOMQB_020_VW37.rod
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 961 D    HW: 5E0 920 961 D
   Component: KOMBI         233 2210
   Coding: 27A402082180A60001082A00000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 008031
   ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
   VCID: 295948A348F92BCE64-807C
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AA    HW: 3Q0 907 530 C
   Component: GW MQB High   442 4366
   Revision: --------    Serial number: 0008958511
   Coding: 030100047F085700FA00025C080F00010001070000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_GatewNF 013025
   ROD: EV_GatewNF_VW37.rod
   VCID: 6ED37BBFB1970CF6F1-803A
   Alternator:
   Component: 1-01-03-01-04
   Multi Function Steering Wheel Control Module:
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 4409960603
1 Fault Found:
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 148
                    Date: 2000.00.00
                    Time: 00:00:00
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: OFF
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 393     HW: 5Q4 959 393
   Component: TSG FS        007 0006
   Serial number: 0000067688935
   Coding: 001000208001020000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 55A1345334015F2E10-8000
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000314234
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
   Component: EPS_MQB_ZFLS  119 1021
   Coding: 81
   ASAM Dataset: EV_SteerAssisMQB 008022
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D718CF3AC71A76E38-8068
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392     HW: 5Q4 959 392
   Component: TSG BFS       007 0006
   Serial number: 0000067401469
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000321588
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 842 A    HW: 5E0 035 842 A
   Component: MU-S-D-ER     040 0421
   Serial number: S7E00507132168
   Coding: 03730100FF0000001111120100A800002F0001860100010002
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2149508330C9E38E3C-8074
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 605 B    HW: 5E0 919 605 B
   Component: ABT_Std_Plus  H50 0022
   Serial number: SKZ8Z9NK6006WL
End-------------------------(Elapsed Time: 03:31)--------------------------
He didn't really help in regards to the issue.
So just asking in case anyone on here could help?
This is just from a bit of googling out of interest (so don't take this as gospel), but it sounds like the button modules are replacements and the car hasn't been told to expect replacements (if that makes sense).
Have you the information on why the car was registered as a Cat N and then what repairs were carried out on it? I'm just wondering if that steering wheel isn't the original one.
Cat N was recorded for rear quarter. I've noticed that the radio bit shows vrs when it boots up. So assume someone's swapped bits before it was wrote off.
Wondering now if my mfsw parts are actually compatible with each other.
Slip ring - 5Q0 953 549 E
Gateway - 3Q0 907 503 AA
Harness - 5JA 971 584
Buttons - 5E0 919 719 L
Any thoughts?
Changed my airbag harness and buttons for different ones to see if it cured any issues.
Horn now works!
But mfsw buttons still out of action.
Grrrrr!!
Yes, the MFSW Buttons need to be coded in. Your scan showed that the car wasn't expecting those buttons or the buttons haven't been enabled up. I suppose in my mind is whether the car is expecting that functionality or not. If they have been retrofitted then you may need to speak with @langers2ktto see if he has the coding for you or otherwise it might be worth paying for an hour on ODIS to get the Skoda chief tech to code the buttons back in.
If I remember correctly, 5E0 919 719 L are from a Yeti so won't work in a MQB platform car like a MK3 Octavia 🤔
This is really sounding dodgy with the number of parts which appear to have been swapped within the car considering you say the write off was for rear quarter damage.
Yea you're not kidding 😆
Been driving it since the horn's been working, its flawless! Flew through MOT y'day, just recommended i change my rear tyres, as they are getting low.
