Rob's Mk1 VRS Combi
  • Replies 117
  • Views 17.6k
  • Slow progress, but here's a few photos of the first bits to be painted!   Both the front and rear bumpers took quite a while to bring back to a respectable condition, but I'm really pleased
  • Poor man's S4 Avant...  Until I can get the money together for a B7 RS4 this will keep me entertained! Got lots planned with a BBT K300 turbo next on the shopping list.
  • Got a few bits fitted, and out of the paint booth... First time it's seen daylight in 3 months! 😍
Looks nice enough :thumbup:
And, from your description, sounds a lot like ours when we bought it a month or so ago - even the mileage is similar.
Can't help with any advice, sorry, I'm treading water too...
One thing I have realised is the surprising lack of spares (the stuff that I need, anyway).
Cheers bud,
I knew the old girl would need some work but that's fine I enjoy tinkering with cars.
My only concern is that I have a bought a daily that I will end up fettling more than the eventual track toy! 😂
I have already found a few bits I need on ebay, so will check over the car again tomorrow and put together a list before I start buying!
  1. The "missing" headrest obscures an annoying amount of the rear vision.
  2. 16" wheels were standard on the vRS estate, but the 17" off a hatch will bolt straight on; you won't even have to change the bolts.
  3. A good remap is available from several reputable tuners.
Welcome to the forum.
The car looks to be in good condition and is on a similar mileage to ours.  I use mine each day and a bit like you, I enjoy fettling as I get to know the car and find things that need sorting.  I'm two years in with this particular car and I'm still picking away at the list of things that need replacing or changing.
There's all sorts you can do to the car to build on the original spec.  Some would say to leave it standard, others like me prefer to work through the car and tweak here and there as you see fit.
Before you modify anything though, when was the timing belt last done?  I've recently had the timing belt, tensioners, water pump, thermostat and oil pickup pipe replaced which should help keep the car going for a couple more years.  If it's all been done on yours that's great, if not I'd look into how much it will cost.
Keep us updated on what you're doing as it's always interesting to see what people are up to with their Mk1 Octavia.
Managed to find a set of 17" spiders local to me, which I'm collecting tomorrow!
Depending what condition they are in I will fit them straight on, failing that I will get them powder coated the correct silver.
What's the reccomend tyre size for the 17" wheel?
Thank you for the warm welcome!
I do intend to keep this thread updated with what I get upto regarding the 'hearse' as my wife has nicknamed it... 😳
As for the belts I was quite keen to make sure that had been replaced.
Fortunately the belts, water pump etc were all replaced about 15k (2 years ago)
So hopefully that one particular service item won't cause me any issues!
The original is 205 50 17".
Quite a lot of people moved to 225 45 17" as there is more choice, the tyres are cheaper & it only affects the speedometer by about 0.4%.
That's quite a big jump, I would of thought the next step would of been a 215/45/17
I assume as plenty of people run the 225 there's no issues with scrubbing etc?
The 225 is fine, I ran that size on the original spiders for years with no issues.  I'm currently on 225 40 18 and again, no issues.
When we eventually get lucky on 17's they'll be wearing 225/45/17's.
  • Administrators
I've only ever run 225/45/17 on mine.
As for my estate (PD130), I've gone back to 16" wheels, as I found it handles a lot better, and my MPG has improved. The VRS version of the estate doesn't have any rear bracing like the hatchback, hence the reason they used the 16" variant of the spider wheels. Try out the 17" and see how you get on, but I would personally leave the 16s on.
Thank you for the heads up Dean,
I will as you suggested try them out and see how I get on. I'll keep hold of the 16's though and stick them back on if it doesn't feel right. 👍🏻
Would a K brace and rear arb sort this?
  • Administrators
I think it would, Craig did this on the Yellow estate. He added a full brace behind the rear seats (where it would be on the hatchback)
Fabulous read, and out does me on my build. Well worth the read if you haven't already.
I haven't,  but I will.. ta for the link..
Right now I'm trying, and failing, to find a tailgate and osr door, and other seemingly unobtainable items (and waiting for suspension to be delivered)
  • Administrators
I'll keep a look out for the scuttle panel, and pollen filter on my search for parts at the breakers Should be going for a trip soon. If I find some parts in very good condition, I'll pick them up for you.
Edited by DeanVRS20VT
So at the weekend I took the time to get under the old girl and give here a minor service and refresh!
* replaced front discs and pads along with fitting kit
* oil change and filter
* carbon cabin filter
* replaced spark plugs
* fitted an oil catch tank
* Fitted a ram air induction kit
Didn't get chance to replace the fuel filter as I ran out of time due to snapping the dip stick guide tube which had the rigidity of soft cheese! 😂 had to get a mate to go pick me up a replacement as it had snapped right at the bottom...
Upon removing the horrid Bosch Super 4 spark plugs that had been fitted with NGK items I found they were all heavily contaminated with oil which I can only assume is due to the rocker cover gasket so that's next on my to do list.
When I took the engine cover off I found the Y piece rubber hose for the pcv system had completely worn through and was doing absolutely nothing! So I'm glad I picked up an oil catch tank kit to rectify that issue.
I may look at removing all the unnecessary pcv pipework and the sai system later down the line but information online is hard to find in exactly what you need to remove etc what with all the different variants of the 1.8t engine.
Also earlier in the week I picked up some 17" spiders which are currently being refurbished and will be finished in a light anthracite, I can't wait to get them fitted along with a set of Michelin PS4 225/45/17's
New Centre caps for them, followed by genuine bonnet and boot badges.
A secondhand and undamaged o/s/f indicator lens replaced my cracked one and a unmarked glove box picked up for a tenner!
Won a secondhand travall dog guard specific for the mk1 estate on ebay for when dog duties are required!
Sorry for the long list and I'm starting to thing this may need to be moved to the projects thread?
I have only owned this car for a week and I'm absolutely loving it!
I'm now finding myself looking at mk4 golf leather recaro interior (is it really just a straight swap?)
And I would like to improve the handling if possible I've been pondering over the KW V1 coilovers and also the Whiteline ARB seems to get glowing reports is there anything else I should consider?
Cheers,
Rob.
Loving the progress. I assume you've got some experience working on cars previous because you seem to know what needs doing. I want to get an older Skoda to try and learn a bit more about mechanic's, any advice?
Excellent stuff....
I've had my sai deleted but haven't removed it yet, the pcv is on the hitlist too.
I prefer the mk1 vrs seats to mk4 golf leather (we had a mk4 before this that I fitted a leather interior to), iirc the fronts should be a straight swap - not sure about the rears.
We still need a glovebox latch, ours is bodged... Not really worth buying a whole glovebox for.
If things pan out I'm looking at offloading ours and getting a scooby next year but it's going to be hard to let go... Something really nice about the mk1 - it's been a while since I've liked a car so much.
Thank you, but I've had no formal training although I did work in a garage and used to be an MOT tester, I've always just liked tinkering with cars.
But I know my limits! I won't try and pretend I know everything in which case I seek professional advice!
That being said from what I've experienced so far working on my MK1 is that it's very simple to work on I would imagine it being a great vehicle to practice on and get used to working on cars.👍🏻
On 09/08/2021 at 19:22, Evil said:
Excellent stuff....
I used to have a heavily modified version 3 impreza sti type ra and I miss it dearly, although it was always breaking down and I ended up selling it with a blown engine as I didn't have the heart to continue with it.
Taking about seats I did a thing today...
A set of mk4 golf leather recaros from a 5 door car with heated elements.
The plan is to get them fitted along with a black carpet (which i have also bought) and get them wired up and working from an OE heater control on the centre console!
Very excited and very happy with the seats they are very comfortable and supportive!
They seem to be in excellent condition apart from dust and a few marks, but hopefully they will clean up well. 😊
  • Administrators
Done well to find them, have yet to come across a set close to me from a 5 door to go in mine. 😁
Thanks Dean! I'm pretty chuffed with them, and I thought £430 was a decent price for the pair including the rear bench and an armrest.
The armrest of course requires the obligatory catch replacment! 😂
I was also looking at Audi S4 seats but they are a fair amount more, and now looking at them these mk4 Golf Recaros IMO suit the Octavia better.
Got my freshly refurbished 17" spiders back, and had them fitted with some 225/45/17 Michelin PS4's.
I'm really pleased with how they've turned out!
Looks much more purposeful in my opinion, just needs a slight drop in ride height and maybe some spacers to get the stance perfect!
The seats and carpet are in!
Just got home from work (easiest place to carry out this job)
It has been an absolute joy removing the very tired and worn grey carpet and replacing with a black variant from a mk4 golf.
Along with a set of Recaro heated leather front seats, rear bench, and a leather armrest also from a mk4.
A fairly straightforward job made easier by using the many guides and information found on this forum!
It's improved the look of the cabin massively and the seats are much more supportive than the original seats.
Next on the list is to wire up the heated elements and get them working via the original switch I fitted where the blank used to be.
From what I've read I need to get a loom from Kufatec, and a relay and then link it all up!
Edited by RMDavis
  • Administrators
Excellent work! Nicely done. Heated seats for the win in winter. 😌
