oil sensor - workshop!
Hi all, I have a strange problem with my oil sensor.
it began by showing the warning in orange, but only when my car got up to temperature (90 degrees +)
My oil temp shows accurately up until the point where this warning shows up, and then changes to show ( --- ) and intermittently shows the correct temp.
the reading does not jump about and is consistent, but every time when the car warms up.
I have had my oil sensor replaced (the one on the sump) and it went away for maybe 1/2 days but then came back with slowly increasing regularity.
I have scanned it with obd tool, however only things showing are lambda / 02 sensor which I will be doing soon - (CAR IS NOT RUNNING ROUGH OR SHOWING ANY SIGNS OF BEING 'UNWELL')
INFO:
2016 octavia vrs manual fwd hatchback
65,000 mi
Can anyone help me?
  • 1 year later...
Did you get this fixed? If so which sensor was it? I’ve just started having the same warning appear intermittently.
