Columbus or Amundsen Retro Fit?
Hi all,
I have a 2014, mk2, CR105 Fabia, Monte Carlo estate, without maxidot.
I want to fit a second hand Columbus or Amundsen unit with GPS + Bluetooth.
May I ask is this a direct swap? is there something I need to do? Or is it plug and play? I have seen people say about VCDS? Will this be needed?
It's a fairly straightforward swap, I did it on ours last year. We went for Amundsen plus with integrated Bluetooth. Apart from the unit itself you need microphone and GPS antenna.
Thanks Chimaera, would I not need to do any thing regarding VCDS? I have just been reading a few posts and some people have flitted but have sound issues? Is this something I don’t need to worry about?
I fitted an amundsen first which was great and was plug and play, but later updated to a colmumbus unit I got at the right price as it was also DAB.
I have messed with endless settings for the sound and for me I think the Amundsen sounded far better in the Fabia to the point I am thinking of going back.
Edited by UrbanPanzer
There's no definitive answer I'm afraid. But generally yes you'll need to use VCDS to make it work,
Chases Rusty, I have just purchased the VCDS now just encase. I don’t have a clue how to work the program. Is it fairly straightforward?
Sorry Rusty auto correct. Cheers :)
I'm hoping you bought a genuine cable & not a rip off? If you bought genuine then there's  a world of assistance on https://forums.ross-tech.com/index
which will point you in the right direction of what's possible and how to do the basics. If you bought a rip off, then you're on your own I suspect.
Hi Rusty, I have brought a second hand one. I hope it will be ok fingers crossed. Thanks for the link :)
