Outside Temperature Sensor
Hi,
Be gentle! Does anyone know where the outside temperature sensor is physically located on a 2010 Yeti?
I'm getting various erroneous readings (from -28degC upwards) changing every minute or so and would like to check the sensor and any connections to the loom.
Any ideas?
Passenger side, behind the lower grill under the number plate.
It's probably the sensor itself.  The one on my old Mk5 Golf which is probably the same part, failed when it was about 8 years old.
