Spare wheel set for 2018 Superb sportline
Hi Guys I have just bought a 2018 2 liter sportline. It came with the tyre repair kit which I am not keen on Does anybody know where I can pick up a space saver spare wheel  kit for the car as I would drive happier knowing I had a proper spare  wheel kit in the boot Thanks guys in advance
Have a look at eBay.
Hi Simon Yes I have considered ebay but wasnt sure as my superb has 19 inch wheels if an ordinary 18 inch spacesaver would work Thanks again
If you don't find one see if there is a single sportline alloy for sale.
Edited by Simon TDI Sport
A sportline alloy won’t fit and the boot floor will sit proud.
You’ll need a 16 inch space saver steel wheel, it is made to go with the 19s
I’ve got a an 18 inch space saver, because I put a full size 18 inch as a spare instead.
Spare wheel replacement kit
Designed for: SUPERB III.
https://eshop.skoda-auto.cz/cs_CZ/sada-pro-vymenu-rezervniho-kola/p/3V0093860B
1359CZK is about £46.98, ie. the foam and jack part of the full size spare wheel kit is cheap.
If you use the OEM part number 3V0093860B you should be able to order this kit through a local Skoda dealer's parts department.
Then you just need a 16" space wheel, such as 205/55R16 fitted to a 6.5Jx16 ET46 5/112 57.1 steel rim.
Edited by Carlston
Thank you for the info above  This helps a lot
Spoiler
  1.
I’ve got a skinny space saver for sale, it should of said ( surplus to my requirements, as I’ve gone for a full size spare instead)
