Software Updates
2 hours ago, simonharper said:
ah ok...
Sorry, just realised that sounded a bit rude… thanks for the suggestion, even if it wasn’t particularly helpful 👍😂.
  • Replies 50
  • Views 16.2k
  • I've just been starting the update and leaving the car... it seems to finish doing them even when off/locked.
  • I’ll leave it for a bit and see how I get on.  Only just got the car.  Thanks for your help, appreciate it
8 hours ago, simonharper said:
Just noticed if you long press the Menu button, you'll get a (secret?) technical menu appear where you can see all the versions of software installed. not sure if that helps?
Is there a safe way of exiting the said long press menu??
Just press the Home or Menu button.
No worries. Didn’t take it as rude at all mate 👍🏼
have a lovely long weekend.
  • 5 months later...
Hi all.  Newbie :).  I can see reference above to software updates not being listed on the Skoda portal site (which I have seen for myself) - does that mean I should still try to perform an update in-car ?  I have a 2018 Kodiaq Bolero so I am under the impression I can only update via the SD card, and so if there are no updates available on the portal, then that's it - no further updates can be done ??  Thanks !
https://www.briskoda.net/forums/topic/470449-i-need-bolero-update/?do=findComment&comment=5702530
Press and hold down the Menu/Setup button for about 10 seconds, then you will enter the hidden engineering menu where you can find the Software Train information and the correct update button.  As seen in 2nd picture on link above.
The software update portal is as much use as a chocolate fireguard, not sure anyone has seen an update they can apply themselves.
Many thanks varoom.  So why don’t Skoda provide updates then ?! Argh.
Is it possible for me to get the latest ?  Where do they come from ?  Cheers again.
No idea why they don't supply updates there (maybe they do, just never seen one)
Odds are they don't trust us to apply them correctly, so if they don't supply any... No comeback on them.
Post up a picture of your Software Train information and I can check for you.  Mine are from VAG group, not a website.
6 hours ago, varooom said:Post up a picture of your Software Train information and I can check for you.  Mine are from VAG group, not a website.
Thanks again varooom, here you go…
0480 is available if needed.
Is it worth me bothering ?
If things are stable, you can leave alone.
But I have updated mine, as have many others.
50/50 really.
50/50 really.
Hi Varoom,
I’m using a 2022 courtesy car at the moment and I notice that Skoda have fixed the confusing display of the mute/unmute button that appears on my 2018, see thread and pic below.
Do you know if this is also fixed in the software update we were discussing above ?
Thanks,
Nick.
https://www.briskoda.net/forums/topic/464853-phone-mute-function-is-reversed/
Edited by ngood77
3 minutes ago, ngood77 said:
Hi Varoom,
Thanks,
Nick.
I am not sure if that car in the picture is using the same software train?
No change logs from mothership, only via reading the TPI documents can you guesstimate what is fixed.
Ok I see.  I guess I’m expecting a bit much from a car company - they’re not Microsoft after all 😀.  Cheers again.
You can use the same process to bring up software train, looks like MIB3 unit to me.
Hi All, I am new to this site but my Kodaiq keeps displaying a software update is required and although I keep selecting download, the message goes away, only to return the next time driving the car, how can I tell what the latest is on my car and what the latest update should be?
Hello,
can anyone tell me, how do you check or where do you check what is latest software for you car ? I have kodiak FL 1.5tsi dgs. First registration was in march 2022. How do I check or where do I check what is latest software for my car and for my infotainment system Amundsen MIB3. How to check what is my navigation map version and is there any newer because I did not have any updates for very while.
Thx !
Forgot to write that my software version is :
Hardware : H22
Software : 0304
Navigation database 23.2
Radio database 1.30.24
Hi @varooom - hope you’re well.  I tried to message you but it said you can’t receive messages.  I’d like to move forward with a software upgrade if you can help me please.   Many thanks
I suspect his inbox is full. He last visited on 27th August 2023, so doesn't look to be active here anymore.
  • 7 August, 2023
Yeah I should have checked first.  Anyway I have the download now
Sorry for not replying, but I do not receive message notifications from this site!  Just for info I still receive update notifications on screen but ignore them now as they eventually go away, especially after my last service at Marshall dealer, they said that they did not do anything to the cars system.. but it does not show updates as often now!  I just wish TomTom could provide their maps for Skoda system as I would pay for it being far better than the current dated system.
Hello
I would like to ask you for your help, because I have a display problem on my KODIAQ 2017 with a MIB 2.5.
my 360 camera displays a black rectangle instead of the vehicle
Can you tell me how to solve this problem?
thanks
Sorry my Kodiaq does not have cameras, maybe someone else will reply.
