Sinosmart Rear view camera swing+
Hello everyone, i bought rear view camera and i cant get it to work, everything is plugged but it wont turn on, would anyone be kind to help me with coding please? Would prefer obd11, am not sure what previous owner of the radio coded and not, but he said in hes car camera was working, i have fl swing 6,5 mib2
thanks
Most likely issue is failure to plug connector in correctly. It's pretty stiff going in and is a right pain to fully locate correctly.
Don't try and "pull" it into place with the locking mechanism, use careful force to push it in all the way, then use the locking mechanism to lock it in place
This thread has everything you need.
(Edit: Not my thread, this was down to @weylandwho deserves the lion's share of the credit for it.)
Edited by EnterName
I have a 5E0 035 871 A - MU-E-ER 852 6490 Radio SwingSoftware ver: MEN2_EU_SK_P5040L.
The thing is that there are people who seem to have found solutions: https://autofidelity.com.au/product/integrated-rear-view-camera-system-with-dynamic-guidelines-for-vehicles-with-swing-radio-for-skoda-octavia-5e/
Not in Europe, though..
1 hour ago, blakcrp said:
There are multiple versions of the Swing, some with video chips and some without.
That camera and many others will work if the Swing has a video chip:
Photo in the logbook of the Skoda Octavia A7 Mk3
I'm not sure if the 5E0 035 871 A has a video chip but you could check yourself by opening it up. Otherwise, Pab might know.
32 minutes ago, blakcrp said:
Yes, I've seen that - thanks! Apparently A is compared to B on that pic, and A lacks the chip.
Please note it is a 5J0...A vs 5E0...B so may not be the same as your unit.
33 minutes ago, blakcrp said:
That won't help if there is no video input on your headunit.
Instead, you'd need something like this which can output directly to the screen: https://www.car-interface.com/vendita/en/interfaces-a-v-video-skoda/1552-video-interface-for-skoda-with-mib2-entry-radio-swing.html
Even is that is compatible, given the price, you'd be much better retrofitting a new unit with camera support.
That being said, your headunit *might* have the video chip based on this post on drive2 https://www.drive2.ru/c/581210093853345170/
The best/quickest way to check is to open your glovebox unit up and verify manually if the chip exists.
Spot on! I missed the J. I think I shall split the can and look for the chip.
On the other hand, it looks cheaper to fit a new unit, but I believe that if we factor in the ODIS activation and the service hours, it could be cheaper to buy the unit and the cam and fit them myself - I'll work out the math..
Thanks for a great help!
Lo and behold:) my 5E0 035 871 A (MIB_Gen2), without glove-compartment unit(!) is compatible with a reverse cam. The worse is yet to come, but I hope I'll manage to install it swiftly. Glad we got that out of the way and I hope it will help others too! Thank you guys and especially you langers2k!IMG_20231012_121749.thumb.jpg.d20bc2cd6674cf5aad5c49cd35881a9f.jpg
  • 3 months later...
Hello i have a skoda octavia 5E 2017 with 5E0035871C radio and i retrofitted a backup camera but i cant get it to work
when i go in 5F at vcds it displays that no coding is available for this ECU
I have powered the camera correctly through reverse light i tested it with a screen works perfect ihave done all the tests but nothing shows up when i put in reverse in the radio . I have programmed the rear camera option in 5F through odis but nothing shows up. Do ineed another radio and which one? @blakcrp if you can help me about how you figured it out i would be greatful
On 18/01/2024 at 14:50, itami said:
Hi, i a have the same HU and cant get the camera to work. What camera did you ordered and was there any coding needed?
Hi! Check if you have the TW9900 chip. That was the only way I was sure that my 5E0 035 871 A (MIB_Gen2) is compatibile. My HU is rather old, but to my surprise had the video processing chip. The C newer ones seem to lack the chip and the video signal.
So, to sum it up: after I was sure that the HU has the chip I ordered the ~90mm camera, as it was the only one fitting. As a sidenote: it was missing a screw, but I improvised.
Good luck!
9 hours ago, vaggos71 said:
Hello i have a skoda octavia 5E 2017 with 5E0035871C radio..
Hi!
As I said in my last post, my 5E0 035 871 A (MIB_Gen2) is compatibile. My HU is rather old, but to my surprise had the video processing chip.
Yours - the 5E0 035 871 C newer Swing - seems to lack the chip and the video signal. The only way to be sure, is to unscrew it, but judging by the signs it doesn't, as it should have worked right out the box.
Anyway, I also coded it to make sure:
M5F-Information Electr.
Coding-07: LCH
-B19: enable b4
Depending on the MY, there might also be another one:
M10-Park Assist
Security-16: 71679 / 20103
Coding-07: LCH
-B03: b4-5 – enable (10) RVC installed
Good luck!
Edited by blakcrp
when i go in 5f in vcds it doesnt show anything in long coding helper
anyway i have odis too i code it though odis i enabled park assist but nothing happens when i put in reverse nothing not even a blank screen
so i think that my radio dont support it i will open it today to look for the chip
but maybe you know what is the code with the chip so i can order it via ebay
thanks for your help mate
On 01/10/2023 at 16:18, blakcrp said:
(more than) happy to report that my 5E0 035 871 A (MIB_Gen2) has the TW9900 chip.
I'll order the cam and return with info if and when I'll set it up.
IMG_20231001_150536__01.thumb.jpg.fb3e755d89d12720e6c5362a384589d8.jpgIMG_20231001_150550__01.thumb.jpg.d67d4748a5a59e3d10db79423f2974a3.jpg
Mine is welded on the board, without a socket. You can read the code from these pics.
My 5F - LCH is also blank, but I have triple checked to make sure that the byte and bit work in my MY.
Edited by blakcrp
If the one posted repeatedly above is insufficient, I'll add more:
Radio Swing 5E0 035 871 A - MU-E-ER 852 6490
SW ver: MEN2_EU_SK_P5040L
