Remote Locking - Cannot Pair Key
1 hour ago, Xhuy10nx said:
pas pump I "acquired"
:bandit:
  • Replies 53
  • Views 8.4k
  • KeithCheetham
    KeithCheetham
    If the remote has never worked it may not be the one for the car so I would expect that to be an issue requiring matching through VCDS or similar - for the time being do not try to do anything about t
  • Breezy_Pete
    Breezy_Pete
    Might also be worth acquiring another fob* to try. I helped a fella recently who'd been told by VW themselves that his RF fob was working correctly, only to find that when I sent him a spare I had, th
  • Breezy_Pete
    Breezy_Pete
    Have you tried this today, i.e. very recently? The status of the key position microswitches in the lock go via the WM.  As you're just down the road, maybe pop up one evening with door card
Nah its like my spare 'brand new' AC compressor for a B7 A4....
Right place at the right time when an opportunity arose... I once got a set of BBS LMs for free off a geezer in Amersham whose interior I was buying for a MK4 golf
Sometimes you get lucky, other times life s**ts on you! 😂
  • Sponsor
18 hours ago, Xhuy10nx said:
It was the blue connector Black/Yellow
Sorry for slow response, was out and about by the time this came through.
As far as I can see this wire is only to do with the electric mirror heating and adjustment switch, so I'm a little surprised that its breakage caused a window motor problem.
It comes from the onboard supply control unit (above acc pedal on RHD), connector XP3 pin 1 and terminates at the 10 way connector of the mirror adjustment switch, pin 1.
What can happen with window motors that are on the blink is that depowering them for a while and then reconnecting the main permanent 12V feed can kickstart them back into proper operation, temporarily. You may have done this incidentally while fixing that wire break?
I hope this isn't what you have seen, as that may result in disappointment again soon, but at first glance that seems likely to me.
Edit: unless...there's a chance that you mis-remembered and it was actually a black/blue wire, in which case that would explain the problem, as that's an ignition 12V feed that acts as on 'wake up' input to the window motor module.
Edited by Breezy_Pete
no it was the black and yellow for sure! Weird... its still working now... who knows
Edited by Xhuy10nx
